Question about Electrolux EI23BC56IS (226 cu ft) Bottom Freezer Commercial French Door Refrigerator
Error message 5y ce - Electrolux EI23BC56IS (226 cu ft) Bottom Freezer Commercial French Door Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Cheryl, I am happy to assist you. Could the error code possibly be SY CE? If so, error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the refrigerator. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Posted on Aug 01, 2013
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Code on door of French door reads error message 5y ce. sounds like it is still running but no light inside or ice maker not working.
Thank you for your post, Carol!
I understand that your Frigidaire refrigerator is displaying an error code of "5Y CE". However it appears that "5Y CE" is an invalid error code. I have noticed the code of "SY CE" and that means there is a communication error at power up. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue it could be possible that there is an issue with your main control board, wiring harness, or user interface board. I would then suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
May 19, 2015 | Frigidaire Refrigerators
WHEN IT DISPLAYS 5Y CE WHAT DOES THAT MEAN?
The SY CE error indicates that the user interface (key #2) and the main control board (key #38) are not communicating properly. You can check the wiring. Unplug the refrigerator and gently pry the the dispenser away from the refrigerator. (Use a putty knife and work around the edge of the dispenser.) Check that the connections are clean and tight. Check the connection under the hinge cover, as well.
If the wiring doesn't have any damage, one of the above boards needs to be replaced. Additional testing will be needed. If you add a comment with the model of your Frigidaire, I may be able to provide information about the parts.
I hope this helps.
Mar 12, 2015 | Frigidaire Refrigerators
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
My side by side on the temp door reads 5y CE. I unplug and replug and it is ok for awhile
Thank you for your question, Friend.
Typically error code SY CE, is commonly referred to an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
Sep 14, 2014 | Frigidaire Refrigerators
CODE 5Y CE WHAT CAN I DO
Good Afternoon Bobby, I am happy to assist you. SY CE is commonly referred that the refrigerator has detected an error code between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 13, 2013 | Frigidaire FPHS2699KF (260 cu ft) Side by...
Lcd reqds 5y ce
Hi John Dirksen- Could the error code possibly be SY CE? If so, it typically means that the unit has detected a communication error at power up. A professional will need to check the wiring between the main control board and user interface. Depending on the diagnoses from the professional either part may need replacing.
Jan 13, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
5y CE code on frigidaire refrigerator water/ice dispenser
Dear Sue,
  • SY CE Error Codes is a very common issue : the display board isn't communicating with the main PCB.
  • Unfortunately, there is no way to test which board is causing the problem. That's why this error can be costly.
  • Try to just unplug the refrigerator for 15 minutes and plug it back in to see if the error goes away.
  • If the issue doesn't go away, then you'll need to replace one or two boards.
  • Usually the Main Control Board under the refrigerator behind the kick panel is the part that tends to fail.
  • If you Change the Main Board, it does not work; you gonna have to replace the Display Board.
  • Try buying these board at an online store that accept Returns without conditions up to a year. Go online and put the boards number into any major search engine. Put the # one by one. You will find many sellers. Carefully pick one and do you homework
Good luck and keep me posted please,
JP
Jan 13, 2013 | Frigidaire Refrigerators
Code 5y ce
Hello Marc Donmoyer - Could the error code be SY CE? If so, then the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need replacing.
Dec 18, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
KEEPS SHOWING A BROKEN TREAD ERROR MESSAGE. I CANOT FINISH A PROJECT! SINGER FURURA CE-150
I have a CE-250 and I was having problems getting this message. After doing some research, I discovered that it was the thread sensor not sensing the thread. Try rethreading it or cleaning out your sensor area. It works for me when I get this message
Apr 23, 2008 | Singer CE-100 Futura Computerized Sewing...
Electrolux EI23BC56IS (226 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
560 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
