Question about 2007 Ford Ranger - XL - Fender Flares - Extend-a-Fender
Replace blend door actuator motor fuse - 2007 Ford Ranger - XL - Fender Flares - Extend-a-Fender
No fuse just for the blend doors
& if it failed ,a new fuse won't fix a thing
Replace the failed blend door
Go to motorcraft web site bring up your truck
& any blend door, then the diagram
Then when you know the failed door write down
the number off motorcraft site & buy on amazon for
a third less than a dealer with a 20% discount
You own a vehicle you should also have an owners manual or be able to check all fuses to accomplish the same thing
Posted on Aug 12, 2013
Blend door actuator is there a fuse or relay
No there is not a fuse that JUST runs the blend door actuator. You likely have a jammed blend door and that destroys the little gear drive in the actuator motor. Good luck.
May 17, 2016 | 2007 Ford Freestar Limited Minivan
Have a 02 GMC SIERRA base model. Not getting air to the floor. (Air or Heat) Replaced the control unit with very little change. The motor for the blend door works fine. Could it be the blend door its...
This is not the blend door if air is coming out somewhere else. It could be the mode door or it could be the in cabin air filter that needs to be replaced.
Dec 09, 2014 | Cars & Trucks
HVAC heater blend door actuator is not working
check HVAC fuse.if fuse okay heater control module could be the problem.
Nov 19, 2013 | Hyundai Cars & Trucks
Blend door postion selector
According to the book, I'm showing a mode actuator and a blend door actuator next to it. Some models use cables and some use small electric motors to move the doors.
Are you sure you are working on the right door ?
Jul 21, 2013 | 1999 Chrysler Cirrus
2008 ranger blend door not working
It can be a jamming door has damaged the actuator motor, both problems are common on this truck. You can buy a kit on line that is called a "HEATERTREATER" THAT ALLOWS YOU TO REPLACE THE BLEND DOOR WITHOUT REMOVING THE DASH, EBAY ALSO HAS THE KITS.
Sep 06, 2012 | Cars & Trucks
When I turn the heat on the drivers side only kicks out cold air while the passenger side kicks out hot air...
The blend door is not working right or the in car air temperature sensor is faulty.
Removal & Installation Air Inlet Door Vacuum Motor To Remove:
  1. Remove the instrument panel.
  2. Remove the air inlet door motor mounting screws. CAUTION
    Do not attempt to bend any part of the air inlet duct door lever.
  3. Rotate and remove the air inlet door vacuum control motor.
To Install:
  1. Rotate and install the air inlet door vacuum control motor.
  2. Install and tighten the mounting screws.
  3. Install the instrument panel.
Defroster Door Vacuum Motor To Remove:
  1. Remove the passenger air bag module from the instrument panel.
  2. Disconnect the vacuum line and remove the mounting screws. CAUTION
    Do not attempt to bend any part of the defroster airflow mode door lever.
  3. Rotate and remove the vacuum control motor from the defrost door lever.
To Install:
  1. Rotate and install the vacuum control motor on the defrost door lever.
  3. Connect the vacuum line to the vacuum control motor.
  4. Install the passenger's air bag module.
Floor Console Register Duct Vacuum Motor To Remove:
  1. Remove the floor console.
  2. Remove the right-side instrument panel insulator.
  3. Working from the passenger's footwell, disconnect the vacuum hose.
  4. Remove the screws and the floor console register duct vacuum control motor. CAUTION
    Do not attempt to bend any part of the floor console register duct door lever.
  5. Rotate and remove the vacuum control motor from the floor console register duct door.
To Install:
  1. Rotate and install the vacuum control motor on the floor console register duct door.
  3. Connect the vacuum hose to the floor console register duct vacuum control motor.
  4. Install the insulator under the dash.
  5. Install the floor console.
Panel/Floor Door Vacuum Motor To Remove:
  1. Working through the driver footwell, remove the two screws and the shield. CAUTION
    Do not attempt to bend any part of the airflow mode door lever.
  2. Label and disconnect the two vacuum hoses.
  3. Remove the mounting screw.
  4. Lift, rotate and remove the panel/floor door vacuum control motor from the door lever.
To Install:
  1. Install the panel/floor door vacuum control motor on the door lever.
  2. Install and tighten the mounting screw.
  3. Connect the vacuum hoses in their original positions.
  4. Install the shield on the vacuum motor.
Auxiliary Air Distribution Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel access panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Remove the auxiliary air distribution blend door actuator screws.
  3. Disconnect the auxiliary air distribution blend door actuator connector.
To Install:
  1. Connect the auxiliary air distribution blend door actuator connector.
  2. Install the auxiliary air distribution blend door actuator screws.
  3. Install the right rear quarter trim panel access panel.
Auxiliary Temperature Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Disconnect the temperature auxiliary temperature blend door actuator connector.
  3. Remove the temperature auxiliary temperature blend door actuator screws.
  4. Remove the temperature auxiliary temperature blend door actuator.
To Install:
  1. Install the temperature auxiliary temperature blend door actuator.
  2. Install the temperature auxiliary temperature blend door actuator screws.
  3. Connect the temperature auxiliary temperature blend door actuator connector.
  4. Install the right rear quarter trim panel.
--- In-Car Temperature Sensor Removal & Installation To Remove:
  1. Remove the instrument cluster finish panel.
  2. Disconnect the in-vehicle temperature sensor connector.
  3. Disconnect the in-vehicle temperature sensor aspirator tube.
  4. Remove the in-vehicle temperature sensor screws.
  5. Remove the in-vehicle temperature sensor.
To Install:
  1. Install the in-vehicle temperature sensor.
  2. Install the in-vehicle temperature sensor screws.
  3. Connect the in-vehicle temperature sensor aspirator tube.
  4. Connect the in-vehicle temperature sensor connector.
  5. Install the instrument cluster finish panel.
Oct 07, 2010 | 2004 Ford Freestar
Hot air comes out the passenger side when air condirioning is on.
The control module or actuator is most likely the cause. You can manually set it for cold air until winter. Actuator is under the dash right by the blower.
Aug 20, 2009 | 2004 Chevrolet Silverado
01 silverado blend door changed /now works back wards!!!
most likely needs a LH (bottom) temp actuator. Located in the center of the dash on the bottom, you have to remove the hush panel on the rh side of the truck
Apr 24, 2009 | 2001 Chevrolet Silverado
Heat flowing on passenger side only
your actuatior foe the drivers blend door is stuck. try unhooking battery for a few minutes have both on heat and hook back up and start up. the actuators will run thru a learn mode and sometimes this will free up.if not you will need an actuator
Dec 09, 2008 | 2005 Chevrolet Silverado
2007 Ford Ranger - XL - Fender Flares - Extend-a-Fender Logo
189 people viewed this question
Top Bushwacker Vehicle Parts & Accessories Experts
Jonathan Buck
Jonathan Buck
Phillip Hicks
Phillip Hicks
David Ellis Rhea
Are you a Bushwacker Vehicle Part and Accessory Expert? Answer questions, earn points and help others
