Question about Kenwood KAC-9104D Car Audio Amplifier
American pro amp 1000 watt vs=3503
The power is on but there is no sound on the sub, when the led greed light is on that means that its on right, what color of light is the protect light
  • 3 more comments
  • oscarc2 Jun 30, 2008
    my amps power light is on but nothing comes out of my subs i tried
    connecting other subs to my amps lines but still nothing and the fuses
    a good i dont know what to do
  • Anonymous Nov 22, 2008
    i have the same problem my power led is on the amp gets his power but nothing comes out my rca cables giving the right signals my power cables to but there's no signal at my speaker cables and the light in the logo is out
  • gabriel agui Dec 30, 2008
    red light is on but the green flashes every 10 seconds
  • melissa456 Mar 25, 2009
    why is my red led light on
  • Anonymous May 11, 2010
    IS IT A 1,2 OR 4 CHANNEL
    Problem Solver:
  • 18 Answers
The Protect light would normally be Red. You need to test your RCA's and make sure your getting a signal to your amp.  I would just buy a new set  or if you have another set just try them.  If you get your amp to power on and all of your voltages are right with the proper signal and your amp fails to turn on you Have a bad amplifier
Posted on Oct 13, 2007
SOURCE:
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
I have a 1100watt sub woofers, and a 1000 watt amp. Will the my sub woofers, or amp blow out or get damaged.
Are those rms wattage?
Anyways, your subs (if you have two) will double the power of your amp, meaning your amp will be under powering your subs. Nothing will get blown out but will never see their full potential. But if you were to use single sub with your amp then you are more likely see the full potential of the sub and amp.
2 subs=2200 watts is just twice the power of the amp output power!
Jan 06, 2011 | Car Audio & Video
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me [email protected]
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
We installed the amp and bass package and the subs are not nowhere near *** powerful we think its the amp and when the remote bass switch when we turn it it doesnt change
what product brand did you install. do you set the amps x-over and gains a sub sonic filter right
need to see if the amp is on check led light on amp. make sure your subs ohm load is correct for the amp.
let us an example fake amp 500x2channel max output 1000watts
if you wire your subs at 4 ohms you 250x2 rms stereo
if you wire your subs at 2 ohms you 500x2 rms stereo
if you wire your subs at 4 ohm mono you get 1000 watts
if you have the input voltage of 14.4 all the time at the amp
whats the equipment power
Oct 14, 2010 | Car Audio & Video
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Not sound
The only thing I can think is the +/- on the speakers are backward or no signal from remote wire....
The green power light is on I presume?
Mar 05, 2009 | American Pro VS1404 Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Shuttle83
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Power Problem, LED Lights up and then shuts off
Do you have the switch or activate wire on the new amp. to the right hookup? If you do, then theres a problem with the amp and if your not a tech these can be a difficult thing to trouble shoot. Take back the amp or seek out a pro to test it on a bench. Good Luck
Jul 24, 2006 | American Pro VS1405 Car Audio Amplifier
Kenwood KAC-9104D Car Audio Amplifier Logo
841 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
