Question about Sanyo DS25390 TV
Straight line picture
I have about a 1 inch picture going across my screen. I use be able to tap the top and it would come back on. Now it's a straight line.
  • 398 Answers
If you were able to tap on the set to get it working, then it means that the solder joints on the vertical output IC are cracked and loose. This is very common on those sets. Now, the pins of the IC could be so loose that they just wont work anymore, and simply resoldering the pins of the IC will cure your problem. However, it could also be that the loose pins have caused the IC to short out inside, in which case the IC will have to be replaced and most likely a small resistor in its power supply too. If you do not have experience working on things like that in TV sets, allow a qualified tech to handle it for you.
Posted on Aug 31, 2007
SOURCE:
BROKEN SCREEN
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Jan 10, 2013 | Samsung 55" UA55C7000 MULTISYSTEM LED 3D...
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Screen
HI, need to see a picture of the line and need to know if you see it on all inputs and whitch ones are you using and does it do it on all of them.
If you cannot send me a picture then let me know what color is the line,is it from left to the right end of the screen and the top and the bottom of the line are they straight all the way horrizontally.
Wait your response then I will do my best to find the solution.
Sep 13, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Televison & Video Logo
51 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
