Maytag centennial washer sensor light flashing
Machine is stuck on sensing and will not operate. It also is making a very loud egg timer noise. I have unplugged machine for extended time but when I plug it back in and turn on its back to sensing and the loud timer noise.
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
SOURCE: Maytag Atlantis Mav8600aww
I have a maytag atlantis mav8600aww and the machine won't spin and drain water out.
Posted on Sep 26, 2009
dwrooker
  • 6 Answers
SOURCE: maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Posted on Oct 06, 2009
appliancguy
  • 86 Answers
SOURCE: Maytag centennial washer - power went out while
Set the timer to any off position. Unplug the unit for 10 minutes. Plug it back in and try that. The worst thing
you can do to a Maytag washer is advance the timer yourself...hope this helps.
Posted on Apr 02, 2011
Lid Sensing light flashing on maytag centennial washer wont start
could be the sensor has gone bad..but try unplugging for little while then reconnect it..it may reset ..good luck...also try Maytag help and support online..customer services
May 23, 2016 | Maytag Washing Machines
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
My washer started making a loud noise and won't drain or spin.
What brand of washer? Does it have a drive belt? If it doesn't have a drive belt. If it sounds like the motor is running, it has a coupler between the motor and the transmission. Very inexpensive and easy to change.
/uploads/images/8_19_2014_4_37_02_pm.jpg
/uploads/images/8_19_2014_4_40_36_pm.jpg
Aug 12, 2014 | Maytag Centennial Top Load Washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Sensing light flashes buy doesnt start
You will need to replace the actuator on the bottom of the machine. Here is the part to order.
Nov 20, 2012 | Maytag Centennial MTW5800TW Top Load...
Washer makes loud noises
Make sure all the guides and rollers that support the barrel are in the correct place and did not fall off or brcome displaced. You should be able to search for the schematic for your model.
Apr 01, 2012 | Maytag Washing Machines
Maytag centennial washer - power went out while washer was operating. When power was restored the washer does not cycle. I have to turn it manually through the cycles.
Apr 02, 2011 | Maytag Centennial MTW5800TW Top Load...
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
