Question about THQ Fairly OddParents: Breakin' Da Rules for Windows
Virtual memory it says that virtual memory is turned off. how do you turn it on?
Cant fix error
this sounds like a HDD problem, your best is to download a live operating system such as knoppix and boot to it, once in check that you can see the HDD it will be shown as "sda1" gather all data and information you want to keep and reinstall your OS
if you are using windows and you havnt made a recovery disk, then you can either contact the manufacturer to send one out or buy the windows install disk
Jan 06, 2014 | HP DX2000 PC Desktop
Tip
Virtual memory Information.
Tutorial Objective
This tutorial talks about anything about the virtual memory and how much virtual memory you need for your system.
Tutorial Introduction & Background
Today application is getting bigger and bigger. Therefore, it requires a bigger system memory in order for the system to hold the application data, instruction, and thread and to load it. The system needs to copy the application data from the HDD into the system memory in order for it to process and execute the data. Once the memory gets filled up with data, the system will stop loading the program. In this case, users need to add more memory onto their system to support that intense application. However, adding more system memory costs the money and the normal user only needs to run the the intense application that requires the memory only for one or two days. Therefore, virtual memory is introduced to solve that type of problem.
Terminology & Explanation
There are two types of memory, which are as follows:
* System Memory is a memory that is used to store the application data and instruction in order for the system to process and execute that application data and instruction. When you install the memory sticks to increase the system RAM, you are adding more system memory. System Memory can be known as either the physical memory or the main memory.
* Virtual Memory is a memory that uses a portion of HDD space as the memory to store the application data and instruction that the system deemed it doesn't need to process for now. Virtual Memory can be known as the logical memory, and it controls by the Operating System, which is Microsoft Windows. Adding the Virtual Memory can be done in system configuration.
Tutorial Information & Facts or Implementation
Virtual Memory is a HDD space that uses some portion of it as the memory. It is used to store application data and instruction that is currently not needed to be process by the system.
During the program loading process, the system will copy the application data and its instruction from the HDD into the main memory (system memory). Therefore the system can use its resources such as CPU to process and execute it. Once the system memory gets filled up, the system will start moving some of the data and instruction that don't need to process anymore into the Virtual Memory until those data and instruction need to process again. So the system can call the next application data and instruction and copy it into the main memory in order for the system to process the rest and load the program. When the data and instruction that is in the Virtual Memory needs to process again, the system will first check the main memory for its space. If there is space, it will simply swap those into the main memory. If there are not any space left for the main memory, the system will first check the main memory and move any data and instructions that doesn't need to be process into the Virtual Memory. And then swap the data and instruction that need to be process by the system from the Virtual Memory into the main memory.
Having too low of Virtual Memory size or large Virtual Memory size (meaning the size that is above double of the system memory) is not a good idea. If you set the Virtual Memory too low, then the OS will keep issuing an error message that states either Not enough memory or Virtual too low. This is because some portion of the system memory are used to store the OS Kernel, and it requires to be remain in the main memory all the time. Therefore the system needs to have a space to store the not currently needed process data and instruction when the main memory get filled up. If you set the Virtual Memory size too large to support the intensive application, it is also not a good idea. Because it will create the performance lagging, and even it will take the HDD free space. The system needs to transfer the application data and instruction back and forth between the Virtual Memory and the System Memory. Therefore, that is not a good idea. The ideal size for the Virtual Memory is the default size of Virtual Memory, and it should not be exceed the value of the triple size of system memory.
To determine how much virtual memory you need, since the user's system contains the different amount of RAM, it is based on the system. By default, the OS will set the appropriate size for Virtual Memory. The default and appropriate size of Virtual Memory is:
CODE
* 1.5 =
For example, if your system contains 256 MB of RAM, you should set 384 MB for Virtual Memory.
CODE
256 MB of RAM (Main Memory) * 1.5 = 384 MB for Virtual Memory
If you would like to determine how much the Virtual Memory is for your system and/or would like to configure and add more virtual memory, follow the procedure that is shown below. The following procedure is based on windows XP Professional.
1-1) Go to right-click My Computer and choose Properties
1-2) In the System Properties dialog box, go to Advanced tab
1-3) Click Settings button that is from the Performance frame
1-4) Once the Performance Options shows up on the screen, go to Advanced tab
1-5) Under the Advanced tab, click the Change button from the Virtual Memory frame to access to the Virtual Memory setting
Then the Virtual Memory dialog box appears on the screen. In there, you are able to check how much the Virtual Memory you set. If you would like to modify the size of Virtual Memory, follow the procedure that is shown below.
2-1) In there, select the drive letter that is used to install the Operating System
2-2) Choose the option that says, "Custom Size:"
Once you choose that option, the setting for Initial Size and Maximum Size become available for you to set. Initial Size (MB) means the actual size of Virtual Memory, and Maximum Size (MB) means the maximum size of Virtual Memory that is allowed to use.
Let's say if your system contains 512 MB of RAM, then the ideal setting for the Virtual Memory is as follows:
CODE
Initial Size (MB): 768
Maximum Size (MB): 1500
Once you are happy with that Virtual Memory size, click the Set button from Paging file size for selected drive to apply the setting for the Virtual Memory size. Then click the OK button to apply the setting.
That's where you can manage and configure for the size of Virtual Memory.
Additional Information
* To maintain the good overall system performance, you should be using the default size of actual size for Virtual Memory and the triple the value of the size of the main memory for the maximum size of Virtual Memory. If you find that main memory plus virtual memory is not big enough to load the intensive application, then you will need to add more main memory onto your system.
Search Keyword
virtual memory
on Dec 02, 2009 | Computers & Internet
My pc cannot restart and it takes long time when turn on
Hi,its software issues,may be u install too many software on it or your windows drive(c:\) does nt contain enough free memory,clear your windows drive,defragment all drives,use check disk for all drives,and add some virtual memory to windows (right click on my computer properties,system settings,advanced,under performance click setting,advaned tab,under virtual memory click change,in custom size initialize at lease 8 GB or 8192 MB)
uninstall unwanted or unused software,
kind regards
Apr 17, 2013 | Dell Computers & Internet
How can i free space for my virtual memory ?i don't need a solution for increasing the size of virtual memory instead i want to free space that has been occupied in the virtual memory.
Hey, You got to free space on your hard drive. The virtual memory resides on your hard drive. but if the hard drive is getting full, this will reduce the virtual memory. So make home for virtual memory by free space on your hard drive.
Apr 27, 2011 | Microsoft Windows XP Professional SP2 for...
A message keeps coming up that my virtual memory is real low. also when i turn my computer off lights start flashing white,orange or red, blue gray and wont go off. what should i do.
Virtual memory is related to your hard disk. Hard disk are setup to act as a memory. Delete some unimportant files to free some more hard disk space.
Sep 11, 2010 | Gateway Profile 5.5 PC Desktop
How to make available more virtual memory
Try Gamebooster to free some memory or turn off the Antivirus, hope it helps
Apr 24, 2010 | Microsoft Computers & Internet
My Vaio Laptop VGN-FW390 can not hibernate properly and sometimes restart during hibernation or sometimes shows an error page when I turn it on after hibernation. ???
Try to Reformat your Laptop and install all the driver. Be sure on the control Panel or click properties then at the appearance tab be sure that on the hibernate tab or on the enable hibernation is checked.
Oct 08, 2009 | Sony VAIO VGN-FW390NAB PC Notebook
Virtual memory
well for a first ,cafee is really dodge and i highly surgest to u to erase ur memory since mcafee caryies a lot of spyware and most likely infected uyour comuputer. i highly recomend that you do not log into any bank website since the spy ware can record your user name and password.
Aug 24, 2009 | HP Compaq FS7600 17" CRT Monitor
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Insufficient Disk Space
nope..Quark is usually a dedicated system approach, where a computer is allocated to that work, solely. It's a fully operational system, and requires as many resources as you can give it. The memory's not the issue. You may want to increase the virtual memory on the disk to the highest level, if you are careful.
May 27, 2008 | Autodesk AutoCAD 2002 for PC
THQ Fairly OddParents: Breakin' Da Rules for Windows Logo
100 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
