Question about Philips Televison & Video
Docking Station won't switch on
Hi, I have a DCM580 12 but it wont switch on. There is power to the machine, the CD light is on and there is a CD in but it wont switch on. What can I do?
  • 24 Answers
SOURCE: IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Posted on Jan 31, 2008
bobfiala
  • 28 Answers
SOURCE: Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Posted on Nov 14, 2008
SOURCE: iPod 8 GB silver will not turn on
I went to the Apple site and found these instructions. They worked for me.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Posted on Dec 27, 2008
  • 6 Answers
SOURCE: iLive docking station not working properly
hello everyone with this problem I bought a use unit last sunday and it was working ok till next day then not sound not light , I try to push every botton and shut off and on but nothing , after many times I decide to open the boom box , and resoldering all the connections take like 1hour but now the unit works perfect the only thing is the blue light never came on , but cd works fine and radio also the dock for the ipod , is working fine
Posted on Feb 17, 2010
SOURCE: PHILLIPS HTD 7001 IPOD DOCKING STATION
for this kind of unit HTS8100 that comes with htd7001 it can only play some ipod. for instance if you want to play music you can use ipod nano but if you want to play video you need to use ipod 4th and 5th generation. because there's compatible issue with this unit because ipod was released after this unit (hts8100) was released
Posted on Apr 19, 2010
My screen goes dark when I use my laptop. I have a docking station with monitor and the machine works fine. However when I undock or start up with just the laptop the screen goes black. I can still see...
Hi wilhejl,
I see that you are experiencing a video issue with you back light on this case,
you mentioned when docked on your docking station you see the video on you monitor but when undocked you get a black LCD screen and see shadows of what is on the LCD screen.
this is a back light issue that you are experiencing.
We can try and check some settings regarding this concern and se if there is anything we can do to correct what you are experiencing with your laptop
As soon as you turn your Laptop on keep on tapping F1 to will bring you to the BIOS screen if the BIOS shows up on you LCD screen without going black then most probably yo may need to change some settings in windows regarding the the LCD and power options.
  • Try docking back into your docking station and inside windows go to power options, and set your system power options to balanced.
  • On your Desktop right click anywhere on an open space to get the menu list click on personalize then click on display then click on advance settings, look for screen refresh rate change it to 59Hrtz then undock from your docking station and try booting into windows without using the docking station to check if the video will show on the LCD again on this issue.
I hope that this can help regarding your case,
Have a nice day.
Apr 07, 2011 | Dell Latitude E5400 Laptop
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My kensington docking station has stopped working
try plugging in any other USB device at the port wherer the Docking station was connected ,... if this device also doesnt work Then update the USB or CHIPSET drivers and also BIOS form the Vendors website also reinstall the appliction from the cd tat u might have got wit the Docking station... take care..
Sep 21, 2009 | Kensington (1500100) Networking Hub
Docking station
Hi!
I would suggest that you by-pass any docking stations and connect it directly via usb charger as most ipods do. And also, try to update Itunes and your Ipod Nano software.
Thanks and good luck! =)
Jan 04, 2009 | Apple iPod nano
Fix video?
If your video was working fine before then it might be a corrupted file driver of your docking station. No need to worry with your computer because it is not your computer causes the problem. It is your docking station.
You may try reinstalling your docking station software using the cd that came with it.You need to connect your system to your docking station when reinstalling the software. if the issue persist after installing the software. Please check if your docking station still in warranty and check their part replacement policy.
Keep me posted.
thanks.
Oct 16, 2008 | Computers & Internet
CHARGING LIGHT DOESN'T COME ON WHEN THE DEVICE IS ON THE DOCKING STATION
The adapter that comes with the Archos 605 must be firmly fixed to the docking station by pressing very firmly with a loud click. It feels delicate so if you only click it lightly it wont connect properly. This is poor design but at least it is OK now.
Aug 27, 2008 | Archos 605 WiFi Digital Media Player
Battery/docking station ac power
There is no manual way to switch from battery to AC, the machine or docking station should automatically switch between battery and AC. There is a power management chip inside the laptop that regulates the power and switches from battery to AC when plugged in. Some docking stations have a chip built into them to do this. Start by ruling out the power supply. Do this by undocking the laptop and plug it in using the power supply that is attached to the docking station and see if the machine is just running off of battery. If it is running off battery, then check the power supply with an ohm meter for the proper output. The output readings are on the supply. If you have two power supplies, and you know one works with the machine, try that supply on the docking station. If the power supply checks good, then I'm afraid the pm chip on the motherboard has gone out. You will need to take this in to have it professionally diagnosed, because it could be a replaceable component that works in conjunction with the pm chip. However, if it is the pm chip, then the motherboard will have to be replaced in order to fix it.
Jul 22, 2008 | IBM ThinkPad T23 Notebook
Dell D600
If the docking station is not charging the laptop while docked, it may simply need to be plugged in using the power cord to recharge the battery.
Jul 21, 2008 | Dell Latitude D600 Notebook
Televison & Video Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
