Question about Crosman Optics
Co2 install when i try to install co2 cartridge as i screww in plunger i get half way an co2 starts to leak out before i can tighten all the way
    Problem Solver:
  • 10 Answers
Your seal is probably out...
Posted on Aug 03, 2013
Gun was working fine, now will not fire even with new co2 cartridge, any suggestions
It is possible the 'new' CO2 cartridge is defective.
If the gun was working fine BEFORE you installed the new CO2 cartridge, try a different cartridge.
Maybe the seal wasn't pearced on the new cartridge. Also, a blockage would also prevent the gun from firing. Check the gas pathways for a blockage.
Aug 13, 2015 | Miscellaneous
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
Cos leaks out
Go to your hardware store and pick up some "teflon tape" the kind plumbers use and cut a strip an inch long and mold it around the top of your co2 cartridge install it and tighten it up and it will cut down on the amount of gas you lose on instalation...:)
Feb 10, 2013 | Crosman Optics
When i instert the co2 in my airmag c11 it just releses all of the co2 and its all wasted what do i do???
Take a short strip of teflon tape and put it over the end of the co2 cartridge, make sure its in straight and tighten, works good.....:)
May 03, 2011 | Crosman (4032)
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
Oct 25, 2010 | Crosman Optics
Air pistol c02 replacement
Well that takes me back! I have an old Daisy 1200 -- essentially the same pistol in a different brand.
My Daisy has a hand-turn screw to hold the CO2 cartridge in place, and you have to tighten it quickly until the leaking stops. It does this by pressing the cartridge up against a nylon washer to form a seal (and of course pushing it into the piercing pin to get the CO2 out!)
With age, I'd expect that nylon washer to get stiff or crack, making it harder to form a good seal. You don't need an exact replacement part, but if that's happened to yours then you will need to replace it with something more-or-less the same size as the original.
May 30, 2010 | Crosman 1377 177 Single Shot Air Pistol
How do you put in a new Co2 cartridge model 1700 bb gun
You should be able to remove the left side grip, unscrew the bolt on the bottom of the grip, insert co2, and then tighten bolt to puncture cartridge. Hope this helps
Jul 15, 2009 | Toys
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
104 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
