Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Gaggia Classic won't turn on, no light at power switch
I bought a Classic three months ago and it worked fine. In order to ship it home, I drained the boiler according to web info - place machine on its back, then upside down and turned switch on briefly to drain pump. I then packed and carefully padded the machine in my hard sided suitcase to ship it home. When I unpacked it there was no visible sign of damage to unit, but when I plugged it in the lights don't come on. I'm trying to troubleshoot the problem but not sure where to start. Any suggestions? Could the process of laying it on it's back and upside down while draining the boiler caused a fuse or limit switch to overheat, or caused something else to go wrong?
    Problem Solver:
  • 11 Answers
I would suspect rough handling of your suitcase, leading to some loose or broken connections inside. I recommend opening it up and looking for obvious disconnections. If you don't see any, the next step will be to use a tool like an electrical continuity tester (which can also test for a blown fuse). There is a lot of information about Gaggia Classic repair online -- just search for "Gaggia Classic repair".
Posted on Sep 27, 2013
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
Posted on Oct 10, 2007
SOURCE: power doesn't come on anymore
I determined that the thermal fuse in the Gaggia Classic that I am repairing had tripped and it is not re-settable. The fuse has the following stamped on it: MICROTEMP SKMAHD G4A00 184C I believe that is what is the culprit for all of us when the "power doesn't come on." Now, what is the rating of this fuse and where can I get a replacement? The fuse is the small resistor-like, diode-like part in a clear tube mounted against the boiler, and it must be physically cut out of the line to replace it!
Posted on Jul 13, 2008
EsWorld
  • 1618 Answers
SOURCE: Gaggia Classic - No Heat, Hot Water or Steam
There is a thermostat on the boiler disconnect and check to see if you can get a reading using an ohmsmeter, if no reading replace the thermostat. If you get a good reading then disconnect the element and check for resistance.
Posted on May 18, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Classic - water not flowing
Remove the screw and shower in the group, then press the brew button, if water flows then clean shower. I will send instructions for descale and backflush. Cut time for backflush by half.
Posted on Oct 08, 2009
SOURCE: Gaggia Classic Espresso Machine - will not pump water
Hi, this is so easy to fix. Firtsly unplug the machine. Then remove the two screws in the top plate so that you can have access to the internals of the machine. You will see the red pump to the left hand side at the back. Remove the two screws that hold the pump in place (use a magnetic screwdriver so that you can pull the screws out). Pull the pump up towards you and then unscrew the thin plastic pipe at the top of the pump . It is the pump that has the scale build up problem. If you the put the water tubes into the water tank and hold a cup to the top of the pump to catch the water you then have to switch the pump on. You will then start to see lots of scale come out of it and the pump will pump more water than you are expecting so be careful. Be sure to cover the internals of the machine whilst you are doing this as you don't want to get water on the electrics and electricute yourself!!! Then rebuild it! Just svaed yourself £100 in having it serviced :-)
Posted on Nov 01, 2009
Gaggia Classic won't turn on, power switch does not light up
Does the red light on the left switch light up when you turn it on?
Mar 10, 2017 | Gaggia Classic Espresso Machine
My new gaggia accademia won't work. It shows error code 19. Can you help me?
Hi, Error 19 is not known by me. Sounds like something is not resetting or has failed. Try turning off the machine at the main power switch and unplug it from the wall for a few minuites. Remove the dreggs draw and drain tray and replace them before you plug it back in. This will allow the machine to reset. Dazza REPAIRER
Sep 24, 2011 | Gaggia Coffee Makers & Espresso Machines
My air classic is only 1 month old went to clean it and the blue light just flickers and then powers off
Where's your rep?! This unit comes w/ a three year warranty. Send it back to fix it. You should only have to pay shipping.
Jul 17, 2011 | Ecoquest Living Air Classic Air Purifier
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
I have a 1992 Lebaron Convertible. @ 36 months
Have you tried jump starting it? Low voltage can cause lots of issues. It could be a bad alternator.
May 17, 2010 | 1995 Chrysler LeBaron
My Samsung HL-R6178W television is not turning on. All that's happening is all three LEDs (timer, lamp, stand by/temp) are flashing. About two-three months ago I had the same problem and ordered a new...
To check and see if it your bulb, remove the screw and pull the lamp assembly from the back. ON the very back where the cover is to access the lamp tape the switch so that it is all the way up and turn the television on. You should here a buzz and see a blue spark. If this is taking place, remove the tape and order another bulb. You will also see the lamp light up from the back without removing anything and just by attempting to turnt he television on. Other things that you may need to check is the lamp cover switch, DMD board, color wheel, fans, but you will need a service manual to check these things. Also, another thing you can try is to unplug the televison and plug it back in after 3 minutes. It acutally sounds like its the switch that closes its circuit when the lamp cover on the back of the television is removed.
Jul 20, 2009 | Samsung HLR6178W 61" HDTV
Gaggia classic
I can deliver it for you. Only I live in Europe and then you have to pay shipping to.
Let me know!
Marco
The Netherlands
Aug 24, 2008 | Gaggia Classic Espresso Machine
Beans stick in hopper
Bob,
Thanks for the help but I was well past that stage. After cleaning half a dozen times, changing beans three or four times, soldering the contacts on the switch, changing it, replacing the whole doser flap sled and anything else I could think to do I finally fixed it. It took me months but in the end it was the doser trap door not allowing the dozer flap to move back and hit the switch when the grounds came down. A simple light bending out fixed it. So...we had a rare mechanical issue. The machine does have a design flaw in that it has a long three inch shoot for the grounds which makes it susceptible to clogs. Do not use oily beans!
Feb 20, 2008 | Gaggia Titanium Espresso Machine
No water coming through brewing head
Hi there, I had a very similar problem with my Gaggia Classic. Worked fantastic every day for two years then one day the brew head was reduced to a very slow drip. I rang some Gaggia service agents and they all said it needs a service ($100-$150). The last one I called told me to descale it before bringing it in for a service as it was probably scale buildup. I told them it wasn't a gradual thing - it just suddenly stopped and they said what happens is the scale builds up to a point where a piece breaks off and clogs the pipeworks leading to the brewing head. So, I used the instructions outlined here: http://www.coffeemachine.com.au/descalin... At then end of the second flush through the steam head, I closed the steam vale to try and push the descaling solution back through the brew head (just dripped through again) then left it for 10 minutes again. Did the same the third time and it went to drip again for about five seconds then bingo - burst back to full flow. Hope this helps.
Jun 02, 2007 | Gaggia Classic Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
277 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
