Question about GE PTS22SCRBS Top Freezer Refrigerator With Ice Box
Loud compressor everytime the compressor shuts down. Itsounds like it is going to tear straight throught the fridge. If I put a towel on the compressor to insulate the sound is this a fire hazard?
  • dreson Jan 29, 2008
    Whenever my GE shuts down (the compressor), it sounds like a TV is falling down a flight of stairs -- about 4 to 5 quick loud banging/thudding sounds. Is this an issue with the compressor or just the mounting of it? Thanks in advance for any help...
  • 183 Answers
This is a faulty compressor, one of the internal mounting springs has come unattached, but the only solution is to replace compressor long term, you could try wedging a piece of rubber or polestyren between compressor and mounting plate base, sorry no other possible solution. Regards Advisor
Posted on Aug 31, 2007
SOURCE:
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Fridge troubleshooting
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Nov 27, 2013 | Refrigerators
I cleaned my fridge only with paper and cloth towel last time. Ever since, the freezer is working but fridge completely shut down. I tried to switch on and off. The light is on in fridge but it's not...
It's not the compressor otherwise the freezer would not be working either. You might first check to see if the settings are set at the factory indicated settings, if the freezer is turned up to cold this will shut off the air flow to the refrigerator.
May 17, 2011 | Samsung Refrigerators
Whirpool Refrigarator Compressor Very Hot Will Burn You and Is not Cooling Properly It is letting freezer melt and not barely cold inside
hey
you either have 3 things an over heated compresser, this wouldnt allow the compressor to cool anything beacuse it has an overload which kicks out once the compressor is too hot, and the compressor doesnt work without the overload. solution: get some paper towels, UNPLUG THE FRIDGE, and run some cold water on the towels and use them to cool the compressor, i like to get like 4 or 5 towels wet them and put them on top of the compressor and get another 4 5 towels wet them put the un the bottom front of the compressor. than use another 4 5 towels and cool the front by just rubbing the middle front. keep repeating this until your compressor is not hot anymore like luke warm or better than buy a 3 in 1 its like 20 dollars and install that ( if you need help i will be more than willing to walk you trough it over this or you can call me too)
and the second thing that it can be is overheated compressor due to the condesner fan not working, and thats simple fix just see when you turn on your fridge and turn the dials all the way up to 9 or w.e option you have. see if the fan by the compressor is working if not replace it its also like 20 bucks
or 3 the worst case scenerio free-on leak it has no freeon and the compressor keeps keeeps working to cool the fridge but it cant without freeon so due to the excessive working lol the compressor overheats and shuts off  if thats the case buy a new fridge
if you want to email me with a response  please do so at [email protected]
Jun 06, 2009 | Whirlpool GD2SHGX Refrigerator
Loud noise from Fan and compressor
i have the same problem with mine. I took the back cover off at the bottom and the fan was going. get a scredriver and barely touch the center of the fan while it is on and if it stops making the noise then it is the fan motor. The bearings are getting ready to go out and it needs to be replaced.
Mar 22, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Loud fridge compressor stays on loud
HI!!! You sem to have a problem with your compressor .The windings are going out..If the frig has a run capacitor change it and see what happpens.If it is still loud then you have compressor problem..Good luck..
Jan 22, 2009 | Refrigerators
Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Loud Fridge
noise is probably the compressor dismounted - it is mounted on springs inside the casing. no cure except to replace the compressor - expensive job
Sep 07, 2008 | GE Refrigerators
Kenmore Refrigerator making loud sounds at shutdown
the compressor has a loose or broken spring inside the compressor, unfortunatly it can not be repaired without replacing the compressor, it could last many more years and it could quit as we speak.
best thing is to let the neighbor know of the problem and what is the repair that way they won't think you are ponning off the machine to them, it may outlast your new one, time will tell
Apr 15, 2008 | Refrigerators
Ge refrigerator compressor
No, Try fiiting a piece of rubber or polestyren under compresser base otherwise compressor needs replacing in any event it will fail eventually rersulting in loss of food contents. Regards Advisor
Aug 30, 2007 | Samsung RS2556 Side by Side Refrigerator
GE PTS22SCRBS Top Freezer Refrigerator With Ice Box Logo
75 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
