Ridgid powerwasher pump asembly model no.3DNX27GSI
Trying to fix my power washer pump but can"t find a diagram of the pump,to see what the parts are?
3 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Power Washer Engine Locked Up
Maytag Neptune MAH5500B Front Load Washer
Hi, My husband said there was... Answer This...
YOUR POWER WASH CAME UP UNDER NEPTUNE WASHERS????????????????????????
Posted on Sep 02, 2008
  • 8 Answers
Odds are the engine is not easily repairable. The cylinder and piston rings are probably scored and will have to be replaced as well as the connecting rod and crankshaft and piston itself. possibly the valves and cam as well. A teardown and inspection would be necessary to determine the extent of damage
I would suggest finding an similar engine of equivalent power and replace the engine. Harbor Freight ( Harbor Freight ) is one source for replacement engines, there are others.
Posted on Dec 03, 2014
Why doesnt my powerwasher pump out water
check for a blocked jet in the end of the wand ( squashed hoses or blocked hose to the wand)
the blocked jet has the same affect as not pulling the trigger and the pressure regulator bypasses the water back into the pump
Sep 08, 2015 | Annovi Reverberi RMV2.5G27D Pressure...
The low pressure chemical injector does not draw in soap
just might be stopped up try compressed air through the ports to see
Jun 20, 2014 | Cat Pump 3DNX27GSI - Direct-Drive Plunger...
Pressure lost
Pump issue. Go here and get the part number for your pump by model number. You can buy direct from Rigid.
https://www.ridgid.com/us/en/literature-search
Aug 31, 2013 | Ridgid Garden
Low pressure from powerwasher wand when trigger is squeezed
THIS POWER WASHERS ARE TRICKY, TO OPERATED YOU NEED TO OPEN THE WATER FAUCET CONECTED BY A HOSE TO THE POWER WASHER , OPEN THE TRIGGER AND THEN START THE POWER WASHER, OTHER WISE YOU WILL RUIN THE POWER WASHER PUMP.
Nov 01, 2010 | Briggs & Stratton Garden
MY RIDGID ROOFING GUN will not feed the nails and then jams up because it trys to shoot two nails how can i fix it?
I would look at the deeder area which is close to the plunger. If not properly oiled, it will jam up like this. See the link below and enter the model number (R175RND) to get the complete parts breakdown diagram. That should help you to open up the unit and check it out. Also examine any O-rings for signs of wear.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJLzi4D70aMCFQo65QodJDG7wQ
Aug 23, 2010 | Ridgid ZRR175RND FactoryReconditioned 134"...
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
I need a manual for ridgid wet/dry vacs model #wd16500
I was unable to find the model WD16500 instruction manual anywhere online. In fact I did even find a link to that products owners manual, but when I clicked through the page no longer exists on Ridgid's site. I was able to find the parts diagram for the WD16500, and the instruction manual for the WD16600 which is also a 16 Gallon Detach Wet/Dry Vac, also with a detachable blower, and the model that even replaced the WD16500.
I also left you the number to Ridgid if you'd like to contact them, they may be able to mail you a paper copy of the instruction booklet.
I hope this helps you:
Instruction Manual:
http://www.ridgidparts.com/pdf/WD16600.pdf
Parts Diagram:
http://www.ridgidparts.com/cgi-bin/etcTable?showTable=1&table=WD16500-Figure1&image=Vac
Phone Number for the Ridgid Company:
1-800-4-RIDGID
If this was helpful, please be so kind to rate my answer as helpful, this is what keeps me coming back to Fixya to help people with their vacuum related questions. Thanks alot, I really do appreciate it.
Chris J.
GoVacuum
Apr 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Water pouring out of the pump on my kew powerwash
Hi, You can get this seal set for a 1502v from nilfisk alto or any alto dealer.
Dec 27, 2009 | Garden
Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Jan 11, 2008 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
