CRC112190000001 Fedders Model number A1Q05F2C
I have a older Fedders unit model number CRB120CNA what is the tonnage of this unit
I don't believe you have copied that number correctly.Look for a serial number. Is this a window unit?
Jun 27, 2017 | Fedders Heating & Cooling
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
I lost my manuel for Maytag dehumidifier model M7DH65B2A. May I download a manuel for my dehumidifier?
Hi! Your dehumidifier was made by Fedders for Maytag. However, Fedders as it used to be, not longer exist. It is now Airwell-Fedders. And they don't provide a download feature. However, you can call their Customer Service Dept 866-829-2440, and they may be able to email you a manual for your model. Be sure to have your correct model number handy, when you call.
Hope this helped you. Please let me know. Thanks.
Jun 03, 2011 | Maytag M7DH65B2A Dehumidifier
I was looking for a manual to download, the fan is bad and I need a parts list. The download on the manual section did not work
Fedders made that unit for Maytag. Check the Fedders website for the same model number (just drop the M off the front of the model number) and you should be able to find what you need.
Apr 25, 2011 | Maytag M7DH45B2A Dehumidifier
I have a emerson a/c model 10HW12K-N and need a control switch part number CRC112190000001. Is there one available anywhere and if so how much and where can I purchase.Thanks Linda
I also need 112190000001. I found it at:
http://www.repairclinic.com/PartDetail/Selector-Switch/112190000001/784649
These are pricy little critters. My shaft broke. I tried cyno acrilate, epoxy but nothing held. I eventually found a piece steel 1/4 D stock and put an all new shaft in. If that had not worked, I would be shelling out $45 for a new switch.
Sep 02, 2010 | Emerson Heating & Cooling
Okay I got a reply for help on my fedder air conditioner, but for some reason I never found the owners manual where I was sent to so Thank You for your help and now I will send the Model #out so maybe...
OK, now with the model number you provided, I can determine that it's an older model and the manual is no longer available online. The part number for the manual should be #CRC23230258N013
This supplier states to email them for price and availability, scroll down a bit and you'll see the manual in the list of parts available.
http://www.appliancefactoryparts.com/humidifiers/fedders/a6d24e7a-k.html
Here's a link with the contact info for Fedders you can give them a call and see if they can provide you with one. I've spent quite a bit of time searching all possible sources for the out-of-print manual and came up empty, although I did find a couple of shops that once had them, they've run out as well.
http://www.fedders.com/contactus.asp
Hope this helps, and best of luck in finding a manual for your AC.
Aug 07, 2009 | Fedders Appliance Air Conditioner Wall
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Heating & Cooling Logo
220 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
