Question about Psyclone Playstation 3 Black Axe Guitar
How can i get a wireless port for a pse3300 - Psyclone Playstation 3 Black Axe Guitar
The mouse cursor on my laptop wandering without control?
This is what they call device interference, You might have to many wireless devices connected to a single USB port on your PC. Sometimes its a struggle between keyboard and mouse both wireless. Solution would be to limit the wireless devices to certain USB ports. For ex: plug the wireless keyboard to opposite USB port from the wireless mouse, vise versa. If you are using a multi-port USB connector, unplug the mouse from the multi-port and plug it to a single USB port on the PC.
Oct 20, 2014 | Sony VAIO Computers & Internet
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
How do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How to hook up a wireless printer to a computer
Does the printer also have some "wired" interface (parallel-port, or USB-port)?
If not, then you need to purchase a router with wireless capability:
1. Connect cable-modem (or DSL-modem) to the 'WAN' (or 'IInternet') port on the router.
2. Connect one of the 'LAN' ports on the router to the network-port on your computer.
3. Configure the wireless-adapter inside the router:
* set an SSID -- the "name" of your wireless network
* encryption-level -- use 'WPA' or 'WPA2'
* a password for your network
4. Configure the wireless printer to connect to that SSID, using the password
5. On the computer, click "Add Networked Printer"
6. Print a "test" page: computer -> wired -> router -> wireless -> printer
Mar 18, 2011 | Canon Office Equipment & Supplies
Is there a port for a wireless card? if not what can i do to make wireless
In order to make your desktop wireless, you will need to buy a wireless card for your computer. The wireless cards are available for PCI and USB ports for desktops in addition to PCMCIA ports for Laptopts in the market. I'd recommend to use a USB one and the PCI wireless card need to be connected to your motherboard whereas the USB one can be connected to any free USB port and you can easily plugin and plugout the same without having to open up the computer.
Oct 31, 2009 | Dell Dimension 3000 PC Desktop
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Feb 03, 2009 | Lexmark X4650 InkJet Printer
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Help
First, FYI, I hope you mean Switch and not Hub and I am to assume your Router's LAN ports are all in use as to why you want or need the 5 port Switch and that you have Wireless Access Points or maybe your Router is a Wireless Router.
Next, you have to connect your 5 port Switch to your Router LAN port. Next you need a Wireless Access Point device to plug into your 5 port Switch. It would be helpfull that all your devices are of the same name brand also.
Now you have a Wireless network.
Thanks,
podum
Sep 11, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Psyclone Playstation 3 Black Axe Guitar Logo
62 people viewed this question
Top Psyclone Video Game Consoles & Games Experts
James Wishart
Are you a Psyclone Video Game Console and Game Expert? Answer questions, earn points and help others
