Question about HP LaserJet 4100 Laser Printer - Plain Paper Print - Desktop - 25 ppm Mono
How to replace a toner cartridge - HP LaserJet 4100 Laser Printer - Plain Paper Print - Desktop - 25 ppm Mono
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Follow the illustrated instructions beginning on page 88 of http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl10335/bpl10335.pdf for removing and reinstalling the toner cartridge.
Posted on Jul 29, 2013
Sharp code f2-64
The code refers to the black toner supply fault. This is usually caused by the toner compacting in the toner cartridge. There have been a couple of instances where the plastic strip remains when the cartridge is replaced. If this isn't the case then the solution is to remove the black toner cartridge & gently but firmly tapping the toner cartridge to break up the compacted toner. Re-installing the cartridge & turning the machine off & then on should reset the error code. If the code remains it may also indicate a faulty toner cartridge & this can be proven by replacing the black toner cartridge with another one. If, after replacing the toner cartridge with a replacement, the code re-occurs then this could indicate damaged toner supply gears which would require a technician to verify, but the most common cause tends to be the toner cartridge is at fault.
Hope this helps.
Dave.
Jun 05, 2015 | Sharp Office Equipment & Supplies
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
Hi- I have an MF8170c. The green "recv'd in memory" indicator is lit and I know there are documents que'ed that are waiting to print. I changed a printer cartridge that was I was being...
Replacing the Toner Cartridges
If printout becomes faint or inconsistent, the reason may be that the lifetime of the toner cartridge has been reached even when a message does not appear. Do not continue to use the toner cartridge when there is a deterioration in the print quality.
The lifetime of toner cartridges for this machine is indicated as follows. The number of pages is based on printing a typical document (with a printing ratio of approximately 5 % and print density set to default).
- Black (EP-87) Toner Cartridge Black): Approx. 5,000 pages for printing paper in size of A4 or Letter.
- Yellow, magenta, cyan (EP-87 Toner Cartridge Yellow, EP-87 Toner Cartridge Magenta, EP-87 Toner Cartridge Cyan): Approx. 4,000 pages of printing paper in size of A4 or Letter.
When [PREPARE NEW* CART] and then [REPLACE* CARTRIDGE] appears in the LCD, replace the toner cartridge of the indicated color with a new toner cartridge.
* Indicates either "C", "M", "Y", or "K"
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite resulting in burns or a fire.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Do not use warm water as this may set the toner permanently, and you may not be able to remove the toner stains.
Use only toner cartridges intended for use with this machine.
Press .
Press or to select [MAINTENANCE], then press .
Press or to select [CHANGE CARTRIDGE], then press .
Press or to select the cartridge to be replaced, then press .
You can select from the following:
-[BLACK]
-[CYAN]
-[MAGENTA]
-[YELLOW]
-[ALL COLORS]
Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
Make sure that the toner cartridge you want to replace is at the position for replacing.
If the spent toner cartridge is not in the replacement position, close the cover, then open it again when the sound of machine stops. Repeat this process until the cartridge you want to replace is in the correct position.
Remove the toner cartridge from the machine.
Hold the grip on the toner cartridge and lift it straight up.
Confirm the color of the label on the toner cartridge holder, then take out a toner cartridge of the same color from the protective bag.
Open the protective bag with scissors, so as not to damage the cartridge.
Keep the protective bag in which the cartridge came in. It may be required when taking out the toner cartridge for machine maintenance.
Be careful not to hold or touch the prohibited portions such as the sensor or electrical contacts. It may result in damage to the machine.
Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
If toner is not distributed evenly, it may result in a deterioration of the print quality. Be sure to carry out this procedure properly.
Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
It may be a little snug, but it will pull off.
Do not touch or hold the developing roller. The image quality may deteriorate if you do. Do not apply shock to the toner cartridge memory or bring it near magnetic waves as this may result in damage to the machine.
Keep the protective cover with which the cartridge from removed. It may be required when taking out the toner cartridge for machine maintenance.
Place the toner cartridge on a flat surface, then pull out the sealing tape (Approx. 45 cm (17.72") in length) while supporting the toner cartridge.
Hold the tab on the sealing tape and pull it straight out.
If the sealing tape is pulled out forcefully or stopped at midpoint, toner may spill. If toner gets into your eyes or mouth, wash it away immediately and consult a physician.
Do not pull the sealing tape diagonally, upwards, or downwards. If the tape is severed, it may become difficult to pull it out completely.
Pull out the sealing tape completely from the toner cartridge. If the sealing tape remains in the toner cartridge, it may result in a deterioration in print quality.
Dispose of the sealing tape according to local regulations.
Hold the grip on the toner cartridge and install it in the machine.
Position the triangular mark on the toner cartridge with the triangular mark on the machine and instlal the toner cartridge.
When the toner cartridge is installed properly, the label on the cartridge and on the toner cartridge holder will be aligned as shown in the figure.
Close the cartridge cover and lower the scanning platform.
The toner cartridge holder will rotate automatically.
Aug 31, 2011 | Canon imageCLASS MF8170C All-In-One Laser...
Refill toner
hi
check this video it is very easy
i have try 3 times in the same cartridge
and works just like the original
Dec 03, 2010 | Canon LASER SHOT LBP-2900 Printer
Reset printer
The toner cartridges for the 8026 have a chip on them which count the amount of toner being dispensed from the toner cartridge.
When the printer counts the amount of toner being dispatched from the cartridge has exceeded the amount of "usable" toner in the cartridge, the printer will display the error showing the toner cartridge needs to be replaced.
Crucial the printer also "writes" to the chip on the toner cartridge to say it is empty----You can no longer use this cartridge by simply refilling it.
You need to replace the toner cartridge on the printer with a Genuine New 8026 toner, this should then clear the error automatically and the printer will again spring back to life.
If you are using a new toner you may;
  1. Have a faulty replacement toner
  2. Have a blockage in the pipe which takes the toner from the toner cartridge to the drum unit
  3. Have a fault with the toner dispense motor
Jul 20, 2010 | TallyGenicom 8026DN Laser Printer
What does it mean when the printer says "prepare new k cart"
It means that the black ink cartridge is going to be used up soon so you would better get a replacement at hand to avoid interruptions.Probably REPLACE K CARTRIDGE will appear sometime later.
To replace cartridge do as follows:
Get a Black (EP-87) Toner Cartridge.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [MAINTENANCE], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [CHANGE CARTRIDGE], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select the cartridge to be replaced, then press <Set>.
    Select [BLACK]
  5. Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
  6. Make sure that the toner cartridge you want to replace is at the position for replacing.
    Ifthe spent toner cartridge is not in the replacement position, close thecover, then open it again when the sound of machine stops. Repeat thisprocess until the cartridge you want to replace is in the correctposition.
  7. Remove the toner cartridge from the machine.
  8. Confirm the color of the label on the toner cartridge holder,then take out a toner cartridge of the same color from the protectivebag.
    • Keepthe protective bag in which the cartridge came in. It may be requiredwhen taking out the toner cartridge for machine maintenance.
    • Becareful not to hold or touch the prohibited portions such as the sensoror electrical contacts. It may result in damage to the machine.
  9. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
    • Iftoner is not distributed evenly, it may result in a deterioration ofthe print quality. Be sure to carry out this procedure properly.
    • Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
  10. Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
    • Donot touch or hold the developing roller. The image quality maydeteriorate if you do. Do not apply shock to the toner cartridge memoryor bring it near magnetic waves as this may result in damage to themachine.
    • Keepthe protective cover with which the cartridge from removed. It may berequired when taking out the toner cartridge for machine maintenance.
  11. Place the toner cartridge on a flat surface, then pull out thesealing tape (Approx. 45 cm (17.72") in length) while supporting thetoner cartridge.
    Ifthe sealing tape is pulled out forcefully or stopped at midpoint, tonermay spill. If toner gets into your eyes or mouth, wash it awayimmediately and consult a physician.
    • Donot pull the sealing tape diagonally, upwards, or downwards. If thetape is severed, it may become difficult to pull it out completely.
    • Pullout the sealing tape completely from the toner cartridge. If thesealing tape remains in the toner cartridge, it may result in adeterioration in print quality.
    • Dispose of the sealing tape according to local regulations.
  12. Hold the grip on the toner cartridge and install it in the machine.
    Whenthe toner cartridge is installed properly, the label on the cartridgeand on the toner cartridge holder will be aligned as shown in thefigure.
  13. Close the cartridge cover and lower the scanning platform.
Nov 27, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
HP LaserJet 4100 Laser Printer - Plain Paper Print - Desktop - 25 ppm Mono Logo
42 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
