Question about Toys
Peg pregeo works in reverse
The vehicle works but the controls work in the opposite direction. (Reverse is forward and forward is reverse)
  • 156 Answers
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Posted on Apr 08, 2009
  • 850 Answers
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Posted on Aug 17, 2009
adamfjeld
  • 1508 Answers
SOURCE: Peg Perego Polaris Sportsman 600
remove the battery and black plastic panel and this will give you access to shifter switch, please verify that all of the connecters are connected to the bottom of the shifter switch
Posted on May 23, 2012
adamfjeld
  • 1508 Answers
SOURCE: replaced reverse switch in peg perego because
the polarity is backwards, switch the wires around on the motors
Posted on Jun 14, 2012
adamfjeld
  • 1508 Answers
SOURCE: Peg Perego won't go forward, only will work in reverse.
shifter swicth is probably disconnected
Posted on Oct 16, 2012
Wheels spinning in opposite directions
the polarity is reversed on one of the motors, if the gear selecter is in low or high gear the wheels should propell the vehicle forward, whichever wheel is not propelling the vehicle forward switch the wires around on the motor
Dec 26, 2011 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Polaris Sportsman 600 ATV the reverse does not work. the 1st and 2nd drive work but when placed in reverse it still goes forward. I do not have a user manual would anyone have any answers
Sep 02, 2011 | Polaris 800 Twin Sportsman Ride on Toy
Train runs in reverse and not forward...Jumped motor, runs o.k both ways..Switched the switches and still nothing in forward...?
this train is only supposed to go one direction, if its currently going in reverse just switch the wires on the motor
Oct 03, 2010 | Peg Perego Santa Fe Express Ride On Train
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
Peg pregeo 800 worked for 30 mins. then just stopped.
Although the problem is not the exact same, it is similar. I finally got mine fixed (see post about does not work when pedal is pushed) My problem was the shifter was bad, or the plug for the shifter was bad. I had to take to Rural King to get it fixed, PP service locations are too far away from me .. hope this helps some.
Dec 25, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Peg perego gator wont work in forward but works in reverse
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
29 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
