Question about Frigidaire ATF6000ES Front Load Washer
Error display Please HELP!!! The washing cycle continues to be interrupted intermittently with the E 10 error display. I push the start button and it washes for a little while until it stops with the error display again. I've looked
  • 2 more comments
  • balcsgirl Jan 07, 2008
    E10 error driving me crazy. It goes off every 5 minutes making it near impossible to wash anything. Also, my bleach & fabric softener containers will not drain...leaving product in the containers. Not sure what to do about that????!!!! I have only had this washer for a year and a half.
  • Margaret Washington
    Margaret Washington Feb 13, 2008
    My washer will run for about 5 minutes then beep with the error code E10, I had someone come and look at it... They would do anything about it because they said that I didn't have a paper in the bottom of my washer under the tub with the error codes... What do I do? I have the extended warrany and can't get anything done about it.
  • Anonymous Mar 24, 2014
    My display is just frozen, doesn't show any messages or errors, just one of the washing cycles. tried to turned it off and back on, push the buttons for 15 sec., nothing helps, it just bipping. Please help
    My display is frozen, doesn't show any messages or errors, just one of the washing cycle. I tried to turn it off and back on, hold buttons for 15 sec., nothing happened, it just bipping. Please help.
  • 725 Answers
E10 is a water supply problem first I would check your water lines.. and check the water valves to see if both are open all the way.. next check to see if the screens at the inlets are clear... and last you may need a new water valve in your wather.. let me know if you want to replace it yourself thanks...
Posted on Aug 31, 2007
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Error code FH
Push the off button once to pause it and then push the start button again.  I have the same problem and this is what I do.  Works every time.
Jan 19, 2009 | Washing Machines
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
98 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
