Question about Motormaster Cv Joint Front Female*-ATV
Motomaster motorcycle jack won't raise
I raised my motorcycle off the ground to store it for the winter using the motomaster jack . Now when I want to lower it to the ground the jack will not raise the bike to enable me to release the lock bar. the pump doesn't seem to do anything. I suspect that the hydraulic fluid may have leaked out. So, what can I do to resolve this problem? Also, in your manual, page 5, lowering the vehicle, point 3, it says "remove handle from ram and place on release valve then slowly turn release valve counter clockwise to allow jack to to slowly lower the vehicle". But your manual does not list the release valve only the release pedal. If this is the same item then how do I rotate the release pedal with the handle? Please advise as soon as possible as I want to use my motorcycle. Thanks. Peter, Oakville.
  • 3,519 Answers
Hi Bogdan:
Seems there may be some confusing instructions.
Here's what I would try. My approach would be intended to get the bike off the stand before I tried to trouble shoot the motomaster jack.
1) Use the handle to rotate the release valve to the right (clockwise) until it is snug.
2) Pump the jack to try to raise it. If it raises, then press the release pedal and use the jack handle to slowly rotate the release valve to the left (counter-clockwise) to lower the deck.
3) If it does not raise, I would use a separate jack to raise it, then follow the prescribed lowering procedure, and at the same time, use the control on the extra jack to manage the lowering.
Once you get it partially lowered, hopefully the motomaster jack will start to function and you can lift the bike far enough to remove your extra jack.
Hope this helps.
To let me know if it works for you, please reply as a comment to this post..
Posted on Nov 08, 2015
I have a 36ft winnebago Chieftain on a F53 chassis. I need to replace the fuel pump in the tank but the leveling jacks seem to go around the tank any idea how I remove them to get to the tank. If at
I dropped the tank on a 34' Fleetwood with the same situation. The jacks were welded on so there was no removal option. What I did was (1) Cut eight 4x4 s into 12" sections. I bolted 4 sections together to make a "pad". One 8" 4X4 makes two pads. (2) Then I pumped the fuel into drums. Free drums are easy to find. A cheap 12V fuel pump and tubing is available from any auto supply. (3) I raised the camper on all 4 jacks. Than I retracted one jack, set a pad in place under it and extended the jack fully. Clockwise I put pads under all the jacks one at a time to make a layer. Then I put in another layer of jacks, round and around, and continued until the camper was up 4 layers. (4) The camper could "roll" forward off the jacks at this point because the wheels were off the ground. I attached a chain to the camper frame and took tension backwards using a come-along chained to a tree. (5) Then I got some pallets from the grocery store trash and put those under the tank. (6) I loosened the hangers for the tank and let it down on the pallets slowly. The hoses have to be removed before the tank drops very far. I worked the pallets out one layer at a time to lower the tank to the ground. (7) I could reach the pump mounting plate so I just removed the screws and lifted out the pump and gasket. (8) installation was the reversal.
If I had to do it again, I would take it to Camping World or a truck garage. They have lifts to raise the camper and jacks to raise and lower the tank.
Nov 22, 2014 | Cars & Trucks
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 | Toro Garden
Back wheel lowering when jacking up car
I am going to assume you are raising the body with the jack.
If so, you would have to raise the car most of the capacity of the jack ( 6 - 12 inches) to get the wheel off the ground.
This is normal. If you have a floor jack you might be able to put it under the spindle that holds the hub bearing.
Dec 18, 2012 | 1993 Subaru Legacy
Video on replacing motor mounts on a 1999 ford escort
I have no video of the job just written instructuions.
  • Park the vehicle on level ground and shut off the engine. Raise the front end of the Escort off the ground using the floor jack. Lower the vehicle onto jack stands placed under the frame to support the car.
  • 2Place the jack under the oil pan and raise the lift plate to the bottom of the oil pan. Remove the engine mount bolt using the 1/2-inch socket wrench. The engine mount bolt is in the center of the mount fitting in clear view.
  • Slowly raise the engine using the jack until the weight of the engine is removed from the engine mount. Pull the engine mount from the fitting and place the new mount in the fitting.
  • 4Lower the engine slowly and insert the bolt into the mounting hole. Tighten the mount bolt to 67.9 foot-pounds using the torque wrench.
  • 5Remove the bolt from the other engine mount the same way as the first one. Pull the mount from the fitting and insert the new one. Replace the bolt to the center of the mount fitting. Lower the engine to the frame and tighten the mount bolt to 67.9 foot-pounds.
  • 6Remove the jack from under the Escort. Raise the car off the jack stands, remove the stands and lower the car to the ground
  • Jul 19, 2012 | 1999 Ford Escort
    How do i get the spare tire to come down
    If the spare tire does not lower to the ground,the secondary latch is engaged
    causing the tire not to lower Your vehicle has an underbody-mounted tire hoist
    assembly equipped with a secondary latch system.It is designed to stop the spare
    tire from suddenly falling off your vehicle if the cable holding the spare tire
    is damaged.For the secondary latch to work,the tire must be stored with the
    valve stem pointing up.
    1.Check under the vehicle to see if the cable is visible.If it is not visible
    proceed to Step 6.
    2.If visible,first try to tighten the cable by turning the wheel wrench clockwise
    until you hear two clicks or feel it skip twice.You cannot overtighten the cable.
    3.Loosen the cable by turning the wheel wrench counterclockwise three or four turns.
    4.Repeat this procedure at least two times.If the spare tire lowers to the ground
    continue with Step 2 of removing the Spare.
    5.Turn the wrench counterclockwise until approximately 6 inches (15 cm) of cable is
    exposed.
    6.Attach the jack handle,extension and the wheel wrench to the jack and place it under
    the vehicle towards the front of the rear bumper.Position the center lift point of the
    jack under the center of the spare tire.
    7.Turn the wrench clockwise to raise the jack until it lifts the end fitting.
    8.Continue raising the jack until the spare tire stops moving upward and is held firmly
    in place.
    9.Lower the jack by turning the wheel wrench counterclockwise.Keep lowering the jack
    until the spare tire slides off the jack or is hanging by the cable.
    10.Disconnect the jack handle from the jack and carefully remove the jack.Use one hand
    to push against the spare while firmly pulling the jack out from under the spare tire
    with the other hand.
    Oct 31, 2009 | 2004 GMC Envoy
    The function that rsiaes and lowers the vehicle doesn't work,
    Lifting
    The following instructions must be carried out before raising the vehicle off the ground.
    • Use a solid level ground surface.
    • Apply hand brake.
    • Select 'P' on automatic gearbox selector.
    Note: If the propeller shafts are to be removed, reference must be made to the relevant operation. To avoid damage occurring to the under body components of the vehicle the following jacking procedures must be adhered to.
    DO NOT POSITION JACKS OR AXLE STANDS UNDER THE FOLLOWING COMPONENTS:
    • Body structure other than approved jacking points
    • Bumpers
    • Fuel lines
    • Fuel tank
    • Brake lines
    • Front or rear suspension arms
    • Transfer box
    • Steering linkage
    • Front or rear differential units
    • Engine sump
    • Automatic gearbox
    NOTE: For certain repair operations, it may be necessary to support the engine under the sump. In this case, a block of hardwood or a rubber block should be positioned on the jack lifting cup to protect sump. Vehicle jack
    The jack provided with the vehicle is only intended for use in an emergency, for changing a tyre. DO NOT use the jack for any other purpose. Refer to Owner's Handbook for vehicle jack location points and procedure. Never work under a vehicle supported solely by the vehicle jack.
    Hydraulic jack
    A hydraulic jack with a minimum 1500 kg, (3,300 lbs) load capacity must be used.
    WARNING: Do not commence work on the underside of the vehicle until suitable axle stands have been placed in their correct position. Always chock the wheels when jacking. The handbrake may be ineffective when the wheels are off the ground. Raising and supporting the vehicle
    To assist in raising the vehicle, jacking points are provided as shown in the following illustrations.
    Raising the front of the vehicle
    Apply handbrake, select 'P' on automatic gearbox selector and chock rear wheels.
    Axle stand positions - front
    Raise vehicle to enable axle stands to be positioned under, either, the front sub-frame, or the recommended customer jacking points.
    CAUTION: Place a piece of hardwood or a rubber block between each axle stand and the jacking point to avoid damaging the body / component. If the propeller shafts are to be removed, select NEUTRAL in the main gearbox.
    Carefully lower jack until vehicle sits securely on axle stands.
    WARNING: Always support the vehicle on axle stands when using a jack.
    Before commencing work on underside of vehicle re-check security of vehicle on stands.
    Reverse procedure when removing vehicle from stands.
    Raising the rear of the vehicle
    Select 'P' on automatic gearbox selector and chock front wheels.
    WARNING: Always chock the front wheels when jacking the rear of the vehicle.
    Axle stand positions - rear
    Raise rear of vehicle to enable axle stands to be positioned under the rear sub-frame. Alternatively, the axle stands may be positioned under, either, the recommended customer jacking points or the front mounting points of the rear sub-frame.
    CAUTION: Place a piece of hardwood or a rubber block between each axle stand and the jacking point to avoid damaging the body / component. If any damage occurs to the washers on the front mounting points of the rear sub-frame, then the washers must be replaced. Carefully lower jack until vehicle sits securely on axle stands.
    WARNING: Always support the vehicle on axle stands when using a jack. Before commencing work on underside of vehicle re-check security of vehicle on stands.
    Wheel-free lift
    The following warning must be read before attempting to lift the vehicle.
    WARNING: The vehicle cannot be supported safely in a wheel-free condition using the wheel-free facility of a four post ramp, and under no circumstances must this method be employedA wheel free condition may only be achieved on a four post ramp by raising each end of the vehicle and positioning axle stands beneath the recommended customer jacking points.
    CAUTION: Place a piece of hardwood or a rubber block between each axle stand and the jacking point to avoid damaging any components. If the propeller shafts are to be removed, select NEUTRAL in the main gearbox. WARNING: The front and rear suspension lower arms must NOT be used as lifting / jacking points. Alternatively, support the vehicle on an approved two post lift with the arms of the lift beneath the recommended customer jacking points.
    CAUTION: Place a piece of hardwood or a rubber block between the lifting equipment and the jacking points to avoid damaging any components. If the propeller shafts are to be removed, select NEUTRAL in the main gearbox.
    Oct 04, 2009 | 2003 Land Rover Range Rover
    Floor jack will not lift car off jack stand
    It sounds like you have MAXED out the absolute HEIGHT that the jack is CAPABLE of extending to.
    Try this to test this theory; Remember though before you !!EVER!! attempt to raise a vehicle with a jack, make sure that the vehicle is on FIRM LEVEL ground and that the JACK is likewise. Even if you have to slowely drive your vehicle a short distance in order to attain level ground, DO IT. THIMK! It could mean the difference between whether or not you live to tell about the flat you changed.
    Get yourself a piece of 'treated' 2"x10"x 2' lumber which you will put in the trunk of your vehicle with your jack. It is now 'married' to your jack.
    Chock the Tires on the opposite side of the vehicle that you will be working on. The weight of your vehicle will be redistributed when you jack up the vehicle. Even though you will have it in 'Park' you do NOT want it to move any at all. The chocks will prevent this.
    Place that piece of lumber beneath your vehicle below the 'jack point'.
    Place your jack squarely on this piece of lumber and slowly crank the jack up, keeping your eye on the jack point where the jack is in contact, until the tire is off the ground about 1/2 inch, any higher and you are just wasting energy and time. Once the tire leaves the ground it is high enough to remove from the vehicle. You may have to raise the vehicle up a bit more in order to replace the flat with a good tire. Be SAFE, Start low and work your way higher.
    The REASON for the piece of lumber under the jack is to distribute the weight that is now bearing on the jack so that it does not depress into the ground. It also provides you with a stable platform to begin with and gives you TWO more inches of height to use with the jack if needed. Use it even if you are on asphalt because depending on the consistency of the asphalt material and how HOT is is from the current weather, the jack could settle a bit into the asphalt and this procedure could prevent this and keep you safe.
    If you are using jackstands, use a piece of treated 3/4"x10" square, plywood under it as well to keep it from settling into the ground. Raise the vehicle only high enough to slip the jackstand under the portion of the vehicle where you will be placing it and still allow the tire to be removed.
    Be SAFE and live to tell the tale. :)
    Apr 20, 2009 | Hand Tools
    Motormaster Cv Joint Front Female*-ATV Logo
    785 people viewed this question
    Top Motor Master Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Motor Master Vehicle Part and Accessory Expert? Answer questions, earn points and help others
