Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Hose assembly how do i install a new hose assembly for a 470 delta series
    Problem Solver:
  • 18 Answers
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.
Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
Posted on Nov 06, 2013
arealplumber
  • 33 Answers
SOURCE: Instructions for the installation of a Delta 470
Here is the owners manual and installation instructions for your particular faucet:
Delta 470
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
philschneide
  • 448 Answers
SOURCE: How do I remove delta 470 kitchen faucet? It won't swivel
If the 470 is typical, there should be two large nylon nuts on the bottom of the faucet tubes that hold the faucet to the sink. First, turn the water off, then open the faucet to drain any pressure. Next, disconnect the feed lines (hot and cold) that connect to the faucet from under the sink (be prepared for some water back flow, so paper towels would be a good idea). After the feed lines are disconnected, you should be able to reach up (usually behind the back of the sink basin) and access the two large nylon nuts (one on the cold and one on the hot). These nuts typically have raised portions so that you can get a grip on them. If you are lucky, you will be able to turn them (lefty loosey, righty tighty) by hand. If not you may have to work for some time with various pliers or other tools getting them to turn. Once you have them off, the faucet will simply lift up from the sink. Installation of another faucet should simply be the reverse procedure.
Good luck.
Posted on Oct 03, 2009
  • 349 Answers
SOURCE: I need instructions on how to install a delta 470
Check out the link for help in this matter for installation for your faucet.
http://www.plumbersurplus.com/pdf/Delta_470-DST.pdf
Posted on Jul 28, 2010
SOURCE: I have a Delta Single Handle Pullout Signature
Had the same problem. Contact Delta at 800-345-3358 and they will send out a replacement hose and clip assembly free! Delta has lifetime warranty
Posted on Jan 12, 2011
packrat1948
  • 528 Answers
SOURCE: How can I remove wand
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Posted on Feb 10, 2011
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Delta 470
Dec 09, 2008 | Delta Model 470: Signature Kitchen...
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
82 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
