Question about Refrigerators
My beko frost free fridge freezer is not getting cold at all-the motors running,the fan is on,the light is on but theres no cold.???any ideas.
    Top Expert:
  • Refrigerators Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Check to see that the freezer fan is running.
If your fridge has dual controls, be sure the freezer control has not been turned up too far.
Check the freezer section for signs of frost on the walls, particularly on the rear and floor panels. Frost would indicate a defrost failure.
Check the condenser coils in back for dust & debris and see that fan is running there.
Be sure that food items do not block air intakes in freezer. A stuffed freezer can create airflow problems.
Posted on Jul 29, 2013
  • 90 Answers
SOURCE: Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Posted on Jan 05, 2008
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Posted on Jul 20, 2008
SOURCE: Beko frost free fridge freezer,
sounds similar to mine. Find the source of the bubbling noise (defrost timer at the bottom), remove the cap and advance the timer with a screwdriver. If you fridge starts working, your defrost timer is faulty.
Posted on Jul 28, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Beko fridge freezer. The interior light still comes on but both the fridge and freezer compartments aren't getting as cold as should (probably about only 20%)
hi there. well if its a standard fridge it could be 1- the stat 2-lack of refrigerant 3-or motor.difficult to check without a visual but if your condenser is nice and warm and the motor is not overheating then it could be the stat.either change it or turn off fridge bypass the stat wire and try.it will over freeze.(keep safety in mind first) if frost free then again condenser warm ,compressor not overhated then likely to b your defrost timer.(normally hiden near compressor at rear/good luck Ali
Aug 26, 2012 | Refrigerators
My frost free fridge freezer has stopped working(beko) the fan inside the freezer is consyantly on the food in the freezer has defrosted and the element at the back is usually hot and now its cold
Please checck to see if your thermostat lines are in order or if some of the connecting wires are damaged bby frost. First of all switch off the fridge and allow all frost to clear. then check for the fan circuit, the auto defrost timer circuit. Now after few hours switch on the fridge. Check to see if the compressor is running the back side is getting warm and the freezer is cooling. If not check if the compressor is pumping well or being short of gas-- get help -. If not the timer could be the culprit as after the cooling takes place the fridge does not defrost. Check this out and the fault is confirmed if your fridge works fine now. Hope you try. Good day
Aug 11, 2010 | Refrigerators
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
We have a beko frost free tall fridge now
is the fan running okay if so could be drain vent blocked also if used for lots of ice making condensate has noplace go
Feb 08, 2010 | Refrigerators
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Freezer cold but not fridge
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
