Question about managemylife.com
Refrigerator filter not runnig
Since we changed water filter icemaker and water filter is not running
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
is it getting water into the mold?
  • Is there power to the icemaker? (voltage check)
  • Check for cube lodged in ejector arm
    Posted on Jul 30, 2013
    No water for maytag refrigerator
    Is the filter down at the bottom of the fridge stopped up? It could be or it also could be a valve closed. Try disconnecting the downstream valve at the filter and see if you have water there. If no, then you definately have a clogged filter. When was the last time you changed the filter?
    Sep 05, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
    Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
    The problem there is going to be one of 2 related causes.
    The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
    That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
    Gene
    Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
    Changed the filter and ice maker not working
    try getting water from the door.Sometimes the tank or system runs dry when changing filter and needs to recharge. Water may not run at first but soon will as system fills. Icemajer should work then. Make sure the arm on the icemaker is down
    Jan 10, 2011 | KitchenAid Superba Architect KSCS25INSS...
    HOW DO I CHANGE THE WATER FILTER - I BELIEVE THAT THE ICE MAKER IS NOT WORKING BECAUSE OF THIS
    The icemaker is probably NOT run through the water filter. Typically the filter is only for the water through the door. Either the water solenoid valve that supplies water to the icemaker is bad or the icemaker is bad.
    Mar 03, 2010 | Maytag MFD2561HE Bottom Freezer French...
    I changed the filter and no ice has been made since that time. No water runs in now. The icemaker worked great until I changed the filter.
    Suggest you take the filter out again and inspect for anything obvious. If nothing problematic seen, replace filter with another new one to be sure and retest. Make sure water tap is opened fully.
    Nov 11, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
    ICE MAKER STOP WHEN FILTER GOT CLOGED
    Run the water from the frig for a while to make sure the filter has run out all the air. The filter needs to fill with water first and then fill the line to the icemaker before you will get ice.
    Apr 29, 2009 | Kenmore 57029 Side by Side Refrigerator
    My icemaker is not making ice
    Check your line running to the icemaker, it may be clogged.
    disconnect both ends and blow through it. Should help.
    Feb 15, 2009 | Whirlpool GS6NBEXR Side by Side...
    Ice maker does not work
    Turn the icemaker off for 15-20 seconds at the rocker switch on the side of the icemaker body (square white box)Turn switch back on and immediately press the feeler arm (white paddle) in and out three time. This should start a test cycle. If still no water after it runs through a test harvest cycle (will take about 4-5 minutes), remove the icemaker and look at the ring finger size plastic tube that allows water flow into the icemaker. It is probably full of ice (because of a plugged filter or some other water supply interruption -possibly while you were changing the filter). If the tube is iced up warm it up gently with a hair dryer being extra careful not to get drops of water in the hair dryer nozzle. Do NOT use too high of a heat setting as that tube will melt... complicating things unnecessarily
    Dec 19, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
    GE refrigerator, leaking water filter
    The area above my water filter in my refrigerator is leaking. I doesn't leak until we run the water in the front of the door or the icemaker runs.I have changed the filer and the problem persists. Is there a part above the filter that needs replaced? The model # is GE TFX26ZPDABB. Thanks.
    May 19, 2008 | Refrigerators
    managemylife.com Logo
    21 people viewed this question
    Top managemylife.com Computers & Internet Experts
    thinksewfast
    Steve
    Paul Bade
    Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
