Question about Stihl HT131
HT131 POLE SAW MANUAL
HOW DO YOU CHECK SHAFT
  • Stihl Master
  • 1,807 Answers
I'll send you a link to the full 'illustrated parts manual' maintenance wise, i regularly oil up the inner shafts and brarings in the tube, also grease up the shaft that has the plastic sleve over it, Because it can become dry and start to grip within the case and vibrate.
Posted on Jul 29, 2013
Stihl pole saw will not spin when pole is extended. Shaft will not stay out.
You must disassemble the shaft assembly.
**NOTE: take a photo of each step of disassembly so that you will have a record of how to reassemble and where all the pieces go.
I have worked with them for over 20 years, it is hard to remember, and there is no book!
More than likely you have an inner shaft driver or bearing that has failed, the shaft my be excessively worn. It is hard to say without seeing what is inside.
Dec 01, 2016 | Stihl Garden
Remington Pole Say
check for a roll pin in the gear or shaft that has sheared off
check that the square end of the drive shaft is not rounded off or that the square drive in the gear is in fact locking on the drive shaft and not turning from worn out
Jun 20, 2016 | Remington Electric Pole Saw
Saw attachment will work but weed trimmer attachment will not turn
check that the trimmer attachment is fitted properly on the shaft as it appears the the shaft drive is not engaging in the head
May 23, 2015 | Poulan Pro PP338PT 8 33 cc Gas Pole Saw...
How to attached pole to the saw?
difficult to know what you mean
if you are talking about a pole saw then it is a saw attachment that is used on the end of a straight shaft trimmer
It has a small chain saw fitted to it and by adding extensions to the shaft of the trimmer you can reach up and cut branches at a height of up to 4 meters from the ground
there is no pole for a regular chain saw as this would place too much weight at the length and besides how would the throttle be worked.
May 21, 2015 | Garden
Stihl ht131 shaft spacers came out when shaft came apart
Here is the parts manual.. it shows exactly how to rebuild the shaft and spacers.
Feb 26, 2014 | Stihl HT131
I have a RYOBI pole saw that starts fine, but there is a disconnect between engine and saw blade. The blade will not turn.
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
Aug 26, 2011 | Garden
I want to attach the chain saw to the pole
ahhhg i would say NO if its made for a pole get the right pole ! you will find that the first time you use it you come back with just the pole and no saw.. and the you break you neck trying to retrieve your saw way up in the tree.. WHY U ASK ? the saw blade will get pinched . means stuck in the cut. and will need another saw to rescue it.. fun huh .if you need a little extra height use a truck bed. never use a ladder . good luck be safe..in the gas tank is a filter. you can use a clothes hanger to fish it out, remove it blow it it out backwards with air . or replace it. if this don;t work buy new fuel lines ,carb kit,carb cleaner spray(parts master #1736 my fav) and a new spark plug. when doing the carb just replace gaskets and diaphragm .. don't worry about all the other stuff in the kit, you are just washing the carb to get gunk or dust out of it .. all back together and wa la.. ning ning niiing.. back in biz.. one other thing that goes bad is the crank shaft seal( the 1 next to the clutch) and it can be a pain to replace ! vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Aug 08, 2010 | Remington Electric Pole Saw
How to attach chainsaw to pole
I am not sure what model number you have, but here is a link the owner's manual for model # 106821A ... http://12.153.20.74/manuals/111219-01B.PDF. On page 15 of this owner's manual explains how to attach the pole to the saw. Just make sure you are attaching the saw that is made to fit the pole or it may not work or be to heavy for the pole. I hope this helps.
Jun 06, 2009 | Remington Polesaw Wizard
Looking for user manual for McCulloch 10'' Electric pole saw
hello i found a printable version of the product information on the mcculloch web sight for your 10" electric pole saw here's a link to it so you can print out the product information http://www.mccullochpower.com/node3829.aspx?pid=85295
Mar 27, 2009 | McCulloch 10" Electric Pole / Chain Saw
Stihl HT131 Logo
206 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
