Pac an140hpec Had dehumidifier running and an exclamation point in middle of a triangle came up in left hand corner and shut down. what does this mean?
gforce3s
  • 31 Answers
SOURCE: yellow horshoe light with exclamation point in middle
thats your TPMS light, Tire Pressure Monitoring System. The light means that one of your tires is low on air, so check them all and fill them to the specified amount, which will be located on the drivers side door jamb.
Posted on Dec 12, 2008
  • 7 Answers
SOURCE: facebook chat has yellow triangle with exclamation point in it???
This happens when you lose your connection, refresh the page and you should be able to continue chatting.
If this doesn't work, then facebook might be doing some maintenance work on their chat module.
Posted on Mar 26, 2009
emissionwiz
  • 75842 Answers
SOURCE: What does it mean when
this is the tire pressure warning.
Posted on Apr 21, 2009
ZJLimited
  • 17970 Answers
SOURCE: what does the warning light - yellow circle
Are refer to the Brake System; in RED and YELLOW condition, continue driving cautiously:
More details about this Warning Lights you can find in the 2003 Mini Cooper - Owners Manual (page 16 and next).
I really hope helps with this (remember rated this help) Good luck.
Posted on Jan 08, 2010
ZJLimited
  • 17970 Answers
SOURCE: what does the warning light of a yellow triangle
Standard Vehicle Stability Assist™ (VSA ®) with Traction Control and Brake Assist Vehicle Stability Assist (VSA) is an electronic stability control system that works in conjunction with the Pilot's drive-by-wire throttle and its 4-channel ABS systems to enhance controllability while the vehicle is accelerating, braking, cornering or when the driver makes a sudden maneuver. VSA functions by applying brake force to one or more wheels independently while also managing the throttle, ignition and fuel systems to help the vehicle maintain the driver's intended path of travel.
The VSA system constantly analyzes data from seven sensors that monitor wheel and vehicle speed, steering input, lateral G forces and yaw rate. It compares the driver's control inputs with the vehicle's actual response. Whenever the actual response falls outside of a predetermined acceptable range, VSA intervenes with a corrective action.
For instance, if VSA detects an oversteer condition, the system may apply braking force to the outside front and rear wheels to counteract the unintended yawing effect. In the event of understeer, VSA may apply braking to the inside rear wheel while reducing engine power to help return the car to its intended course. VSA also provides a limited-slip differential effect for the front wheels by applying braking force to a slipping wheel, thereby redirecting driving force to the wheel with more traction.
There is a button on the lower left part of the dashboard that says "VSA". Push it and the triangle will dissappear (this should only be turned off if you are using a spare tire that is smaller than the rest of the tires).
Good luck.
Posted on Mar 02, 2010
How can I exit my friend's facebook account and log in to my account?
In the upper left hand corner of any page on Facebook you will see a dark blue arrow that is pointing down, click on it and a drop down menu will appear. The log out option will be in that menu.
good luck and thanks for using fixya.com!
Jul 02, 2014 | Facebook Social Network
I accidently uninstalled my sound from my laptop hnow can i install it back
driver rollback, or you can let windows find the driver for it.
click the start button (bottom left corner, windows logo), then right click computer, and left click properties.
the system information screen will pop up, then look to the left of that box for device manager. open up device manager (allow if prompted for permission), look for sound, video and game controllers drop down list. if you see a upside down triangle with a black exclamation point next to sound, right click the device. choose update driver software, which will let windows search for new driver software. make sure you are connected to the internet, or this will not work.
Jan 27, 2013 | ASUS F6A-X2 PC Notebook
Delonghi air conditioner it has a triangle with an exclamation point inside. What does this mean?
There is a knob on the back and bottom of the air conditioner. Twist off the knob and unplug the little black plug and empty the water into a container. I had the same problem and this worked for me.
Jul 17, 2012 | DeLonghi PAC W130 Portable Air Conditioner
My inspire seems to be locked on one screen that has a red triangle with an exclamation running through it. The phone will not shut down. It is frozen.
It is the boot rom menu for the device. Just power it off then back on. IF it comes back then your OS on your phone is toast.It means your phone is in recovery mode. Hold down the volume up and power button at the same time, then select the option to reboot by going up or down with the volume keys and pressing the power button to confirm your selection.
Dec 06, 2011 | HTC Inspire 4G Smartphone
1) is an exclamation point in a circle with rigid edges left hand corner 2) exclamation point within parenthesis on the right hand corner
Need to know the year and model of your Ford and I can look up. Reply to this and I'll get an email letting me know. Little confused at how you are wording it but will do my best to figure out. Is one of them like the picture I have posted below. If it is let me know in the reply and will let you know what it means if it is one of the icons you are seeing.
Mar 15, 2011 | Ford Freestar Cars & Trucks
What is the cheat for the trick book in MTX Mototrax
here are some tricks:
Rock Solid: down-circle-circle-circle
Extended Whip: right-down-triangle
No footed whip: right-down-triangle-triangle
Flatliner: left-up-circle
Superman one handed grab: down-down-circle
Greg's flip varial: up-down-triangle
Heelclicker lander: up-circle-square
Double heelclicker lander: up-circle-circle-square
Disco can: left-left-triangle
Corkscrew: up,down,triangle,triangle
Rodeo Air: Up-circle-circle-circle
No Footed backflip: up-down-circle-circle
Kiss of Death: up-down-down-circleBar hop-up triangle
Coffin-down triangle
can can- left or right triangle
heelclicker-up circle
double heelclicker-up circle circle
superman-down circle
superman double grab-down circle circle
superman one handed grab-down down circle
nac nac- left or right circle
whipped nac-left or rigt circle circle
shaolin-up triangle triangle
lazyboy-down triangle triangle
travis'lazyboy-down triangle triangle triangle
odeo air-up circle circle circle
backflip-up down circle
one foot backflip-up down circle triangle
no footed backflip-up down circle circle
indian air-down circle triangle
dead body-down down triangle
saran wrap- left right circle
scorpion-down left triangle
no footed can-left triangle triangle
cliffhanger-down up triangle
one footed cliffhanger-down up triangle(r2)
extended whip-right down triangle
no footed whip-right down triangle triangle
flatliner left up circle
cordova-up up triangle
disco can-left left triangle
tsunami-up up circle
one handed tsunami-up up circle (R2)
side double grab-left left circle
hart attack-down up circle
gregs flip varial-up down triangle
corkscrew-up down triangle triangle
one handed indian air-dow circle triangle(R2)
ladder-down down circle(R2)
stripper-up up triangle triangle
kiss of death-up up circle circle
helicoptor-down up circle circle
disco can indian air-left left triangle triangle
super can-left up triangle
9 o clock nac-left down circle
barel roll-up down circle right
Feb 23, 2011 | Microsoft Xbox 360 Console
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
Warning signal
I have a yellow triangle with a ? on my dash what does this mean
May 07, 2010 | 2006 BMW 3 Series
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Facebook chat has yellow triangle with exclamation point in it???
Mar 26, 2009 | Facebook Computers & Internet
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
