Question about Dryers
Inglis dryer ifr8200 - Dryers
Inglis Dryer by Whirlpool blows only cold air
check your thermal fuse and your heating element. You'll have to open the back of the dryer, but it's pretty easy to fix.
Dec 19, 2012 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
My whirlpool inglis ele will not come on????
The Whirlpool Inglis has had a lot of problems with the door switch. Which would keep the unit from starting.
Jan 02, 2012 | Whirlpool Inglis IP8200 Dryer
My whirlpool inglis ele dryer will not come on ???
1_2_2012_1_10_24_pm.jpgThe door swtch is a known weak point in the Whirlpool Inglis.
My Inglis dryer has condensation on the inside of
normally condensation on the inside of a dryer is due to a pinched or plugged vent hose i have had this happen also when the dryer vent is very short and goes outside where the temperater outside is cold and moisture will condense on inside of dryer
if you live in a colder location there is a vent system
that you can install that will allow you to keep heat inside not reccomended for gas dryer the vent cap on the outside could also be missing the flap that stop air from going back into dryer hope one of these suggestions i a solution to your problem
Dec 10, 2009 | Whirlpool Inglis IP8200 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
