Question about Video Cameras
How do I get videos from camera on to computer? DVR 558HD mocel
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Is there software avaliable to hook up mini dvr to computer
You need to install an interface card in your computer, and it does come with the software.
You need a card that has the video Input (AUX).
The Hauppauge Win TV HVR-1600 is a Plug-in card with TV and Video Input.
www.aaatvservice.com
Jan 26, 2012 | Mini Dvr Digital Video Recorder For Aqua...
I have Vivitar DVR 518,I recieved from Newport Pleasure coupons in about Nov. 2010. I cut into the package, but didn't realize it had a CD in it. Also,I need intructions for my camcord and need to know...
The DVR 518 uses SD and SDHC cards up to 8GB in size.
You can download the manual and request the software from the manufacturer's web site at
http://www.vivitar.com/products/2/digital-video-recorders/361/dvr-518
The best way to download videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any video cataloging program.
Apr 08, 2011 | Vivitar Cameras
I have a Samsung SL620 digital camera with a Lexar 4GB SD card. It plays great videos and I am able to view them on my computer. However, when I put the SD into the USB of my Samsung LN46C630 LCD...
Probably because the tv doesn't have the correct circuitry to play videos. If you have a VHS recorder connected to the tv, you could download the video to a tape and play it that way. I have a Dish Network HD DVR. It has a usb connector allowing me to download to the DVR and play slide shows and videos.
Sep 15, 2010 | Samsung SL620 Digital Camera
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
Is it possible to use HW173D monitor with DVR and security camera
Unless your DVR offers a VGA output connector, you won't be able to use your monitor simply by plugging in a cable. The monitor VGA input requires separate signals for each color (red, green and blue) and synchronizing signals (vertical and horizontal). If the DVR has only composite video out, you'll need a video to VGA adapter. These are available from many online sources. They aren't cheap since they are active electronic devices, but many are in the $50 to $75 range. Here is one typical result from a Google search for "video to vga converter". You might also check eBay or local sources such as craigslist to see if anybody has bargains.
Feb 10, 2010 | Hanns.G Corporation HW173D Monitor
Samsung shr-1040
Best to get a USB thumb drive and download the video needed to the thumb or flash drive. Put it on the computer and there you can use a program like Snagit to capture the best parts and save it for police. Saves a lot of wasted time
Oct 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
