Question about Siemens Refrigerators
IWD Siemens KA62DP90GB
We cannot get the IWD to work on our fridge freezer, it worked but now the IWD option is selected within a square and will not let us do anything with it, can't press the + button like the manual says and no water is being dispensed, only plugged the FF in about 4 hours ago but water was coming out before we changed some other settings? Help please?
  • 139 Answers
SOURCE: Candy CPC 290 FF
Hello
Well the sheet of ice was caused by the thermostat failing and causing the fridge to continously run therefore causing the over freezing..
Like a car engine if you leave it running for weeks on end without stopping it probably will burn out...
Or like a horse is you have it working day in day out with out rest it will die..
you compressor on your fridge is no more... it ran and ran and now its all worn out .....
The clicking noise at the back of the fridge is the compressor trying to swtich on but it can't
only a professional can legally change over the compressor
as it is a techincal process recharging the fridge with gas
if you need any other help let us know...
you need a new fridge by the way
Posted on Jan 11, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
woodchuck789
  • 4059 Answers
SOURCE: The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Sep 06, 2009
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
SOURCE: Zanussi ZFC 62/23 FF Fridge
zanussi f/freezer and my top door has dropped so the light in the fridge never goes off
Posted on Aug 08, 2010
Why does Siemens KF57U56/16 Freezer works fine, but not fridge?
Check the thermostat adjustment in the fridge section if right up replace the thermostat.
Aug 28, 2014 | Siemens Kitchen Ranges
Siemens iwd off
Iwd off mi e apparsa sul frigo questa scritta cosa devo fare
Oct 14, 2013 | Refrigerators
My American style fridge /freezer - Siemens KA62DS506B stopped producing Ice and water . The panel stopped being lit and there is a msg saying IWD Off
Your ice delivery water soleniod has failed, you can locate the solenoids in the rear lower of the fridge freezer unit where the pipes for water delivery goes in to the unit, locate the Ice delivery solenoid and replace it, easy test is to place a test cord on each solenoid and chech for operation under pressure. Russ
Apr 25, 2012 | Refrigerators
The water will not dispense and the ice cubes will not come out. I noticed on the front panel that IWD is "off" and that it shows "lock"ed at the bottom of the screen. I know that the...
Press Freezer and Super at the same time for 5 seconds to turn Ice & Water Dispenser on. This will remove "IWD Off" indicator. If it is locked, press the Alarm/Lock button for 5 seconds to unlock it.
Feb 17, 2011 | Bosch B22CS50SNS Side by Side Refrigerator
Fridge compatment not cooling
If freezer compartment is cold and fan is working, do a 12 hour defrost and all should be ok.
May 21, 2010 | Refrigerators
American fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Apr 03, 2010 | Freezers
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
I have a siemens frost free fridge freezer. the freezer is working but the fridge part is warm.
Check to see if the fan the blows cold air from the freezer compartment to the refrig is (a) not blocked in either the freezer or refrig, or (b) not working at all. Replacement of the fan is likely very inexpensive - cheap parts, and a possible DIY if you can use a screwdriver and read an exploded view in the on line parts manual for your model.
Oct 26, 2008 | Siemens Refrigerators
Refrigerators Logo
63 people viewed this question
Top Siemens Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
John Tripp
John Tripp
 Mikey
Mikey
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
