Question about Crosley CR3011A-MA iDeco Universal iPod Dock - Mahogany
Remote control issue
Well the problem is that when i put the batterie, the remote doesn't work. So i ckecked the IR LED with my cellphone's cam, and it's all the time on, since I put the batteries. Of course, it doesn't work.
  • marcos oriozabala Jul 30, 2013
    But it's new, it can't be dirt. Should be another thing.
    Top Expert:
  • Crosley Master
  • 12,223 Answers
The R.control according with your explanation is NOT o.k Since the IR LED only turn ON when you hit any KEY, if the IR LED must TURN ON all the time, you open the Keypads, for dirty, corrosion, oxide, and bad contact. Clean with contacts cleaner solvent and fix it. However if the problem remain , you HAVE a SYSCOM faulty, see the diagram attached. remote control issue - d8b03c5c-f4fe-46b6-8c03-99cce976f29a.gif
Posted on Jul 29, 2013
Testimonial: "But it's new, it can't be dirt. Should be another thing. What do you think? could be a bad design? I went to the shop, the bring another, and we tested, and has the same problem!"
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Tip
How to see if your remote control is actually working
For remotes which use an IR connection you can see if they are transmitting using this trick. An IR type of remote will have one or two LED's on the front end. If it doesn't, than it may be an RF type of remote - this tip will not work for those.
Get some electronic device which can view a live image on a screen. A cell phone camera, digital camera, digital video camera, and (I think) even a web-cam will work. If you're using a digital (still) camera, you don't need to take a picture as long as you see a live image on the screen of whatever the camera is pointing at. Take your remote and find the LED on the front end. There may be one or two. (If there's two, one actually isn't an LED, but that's not too important.) Point the front of the remote at the camera (LED's facing the camera), and press buttons. You should see the LED's light up in the live image. While these LED's normally produce light which the human eye can't see, digital image sensors can, and they change this invisible light to light we can see on the screen. (Cool right?) So, if your remote is working then you'll see the LED light up on the display. (To make sure your camera is actually working as I am suggesting here, find a remote which you know does work and try it.)
The LED should light up for every button pressed. If one button doesn't make the LED glow, you may have a bad button - try pressing it firmly. Buttons can wear out. The image of the LED may appear steady or it may pulse or blink on the viewscreen - this is normal.
If the LED doesn't light up, and you know your camera works like this (you've checked a good remote), try new batteries - that solves most problems. Check the battery contacts in the remote - if they're corroded, (white flaky stuff caked on, looks like dried up salt) - you can clean the contacts with a solution of water and baking soda and a Q-Tip. Use a knife to remove any large chunks. Also, some fine sand paper works too. Both the flat contacts and the springs need to be cleaned. Wash any tools (and hands) with soap and water afterwards. Handle corroded batteries as little as possible - or better yet, use gloves.
If you have good batteries and the contacts are clean, and the LED is not lighting up - it's pooched. Try getting a replacement from the manufacturer (call or email/write them), or use a universal remote.
If you've found this tip helpful, please check the box below. =8o)
#Remote #RemoteControl #IRRemote
on Jul 08, 2014 | Televison & Video
My remote doesn't work
possible solution
check remote ir led (infrared led) in IR reciver (any electronics repair shop) the finally u know yr remote was working or not if fail in this checknig then u buy new remote for same model
May 16, 2012 | Televison & Video
My Maestro IR remote no longer works after 10 years
The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
Apr 13, 2012 | Electrical Supplies
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
DVD Player works nut remote control does not although I have put new batteries in to-day and still it does not work
check remote control through cell phone camera (LED showing or not) if not showing LED change IR LED or replace remote control
Aug 17, 2011 | Televison & Video
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
Crosley CR3011A-MA iDeco Universal iPod Dock - Mahogany Logo
61 people viewed this question
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
Lawrence Oravetz
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
