Question about Bradford White M16u6ss 6 Gallon 120v 1500w Utility Water Heater
We have changed the element and is still not working.
Could it be an ignitor? The heater is working and then it's not.
  • Bradford White Master
  • 5,245 Answers
What water heater do you have? Question posted under BW 120V 6 gallon electric.
Element is found on electric water heater.
Igniter is found on gas water heater.
So now it get's confusing what water heater you have.... for example some 6 gallon RV water heaters have both electric and gas. And troubleshoot for that is different than electric water heater.
Copy following link for electric water heater troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Does tank have 2 elements or 1? Which element did you change... why did you change element before replacing thermostat? What symptoms were you experiencing before changing element?
Is this a new heater? Was tank full of water before power turned ON?
Add a comment and describe problem in detail.
Gene
Posted on Jul 29, 2013
Have to reset heater button
possible bad heater element or ignitor
Dec 07, 2013 | Little Giant Water Heaters
We just installed a hot water heater that's
1) Test elements, and if elements are good, then replace both thermostats.
Takes about 20 minutes. Power is off.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Label on side of water heater shows volts and watts.
For 4500 watt elements, you need 30 amp breaker and 10 gauge wire.
Move water heater wires to different same-size breaker.
http://waterheatertimer.org/Color-codewire.html
3) Open the links and do the work, or call plumber to do work, or call manufacturer for warranty coverage.
If your wire and breaker are problematic, then service is not free.
Feb 07, 2013 | Water Heaters
I have a Rheem 82vs50-2. Can this heater's elements be wired continuous for 9.0kw and is there any mfr documention that allows continuous wiring of this heater
You have dual element 240Volt tank-type electric water heater.
You want to change wiring from non-simultaneous to simultaneous.
Copy following link for exact internal wiring diagram, and external wiring change: Remember the wire from breaker box will not support both elements without tripping breaker, so you will need additional 30 amp breaker and 10 gauge wire, or single 50 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
http://waterheatertimer.org/Color-codewire2.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Sep 23, 2012 | Rheem Water Heaters
Need to increase the recovery rate of Rheem 82SV30-2 elect water heater. Has 4500w upper and 3380w lower elements. Was told by County Health Dept that it was possible to wire both elements together for...
Basic information: Typical electric water heater operates in non-simultaneous fashion where either the upper element is ON, or the lower element is ON, or both elements are OFF, but both elements are never ON at same time.
Easiest way to increase recovery. If you have 10 gauge wire and 30 amp breaker, then install two 5500 watt elements. This will not work if you have smaller 12 gauge wire and 20 amp breaker.
Watt rating appears on side of each element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Change wiring.
If you run two separate 10 gauge wires to water heater, with each wire on a separate 30 amp breaker, then you can 'wire both elements together' to operate in simultaneous fashion. The elements are each wired independently of each other, but they can both turn ON at same time, and this action avoids heating lag if you also install larger 5500 watt elements.
Simultaneous water heaters can be ordered from manufacturer, and this is common with 80 gallon models where tank must keep up with larger demand.
Copy following link for illustration showing how to rewire for simultaneous operation:
http://waterheatertimer.org/Tempering-tank.html
Aug 14, 2012 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Our Titan N-120 stopped heating suddenly so they suggested we change the elements. My husband bought 2 elements but apparently he didn't realize 1 is 5000W and the other 5500W. Now could this stil
the bigger wattage elements will heat quicker and consume more power
If they fit , they will work but you may have to check the amperage capacity of the circuit breaker
I imagine you are meant to replace the existing elements which woukd have been half what was purchased
Mar 06, 2018 | Water Heaters
50 gal. reliance electric heater. Water is getting way too hot and the settings were not changed. elements must be working for the water to be so hot. My guess would be the thermostat(s) since it won't...
Thermostats is in need of replacement and sounds like they are sticking. So it would be best to change both out. Turn power off to change them out it would be best for safety issues to change out as soon as you could. I have seen thermostats burn up in compartment on water heater.
Sep 20, 2011 | RELIANCE ELECTRIC WATER HEATER
We have a Richmond 50 gal Rheem model 8MV50-2 that blew out the bottom element. We changed both elements and refilled the tank but the water heater won't heat. Do we need a new tank?
Electric water heater is fully repairable unless it is rusted out.
All 2-element tanks are 240Volts.
If you have NO hot water, then suspects are 240Volt circuit supplying only 120V, reset button is tripped out on upper thermostat, bad upper thermostat, bad upper element.
If elements were not completely covered with water when power was turned on, then elements will instantly burn out.
When filling water heater tanks, open bathtub spout. Wait for water to come out full stream. Then open TP valve on water heater for a moment to remove last of air. Then turn on electricity.
Open following link for complete troubleshoot walk-thru.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Aug 20, 2011 | Water Heaters
I have Reliance electric water heater 501: 40 gallon, 2x4500w. Where do I buy the bottom heating element? I went to the plumbing store and get one but it is a little smaller than the old one. why? I am...
Your water heater has two 4500 watt elements so water heater is 240Volts, and water heater is rated 4500 watts. Both elements are not ON at same time, and this is called non-simultaneous operation.
The element might have been smaller in length, but it will work fine.
Why is it smaller. I don't know. Elements are different from manufacturer to manufacturer.
The 501 does not use a special element.
Local box stores and hardware stores sell elements in water heater department.
The wattage of element is printed on end of each element.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 20, 2011 | RELIANCE ELECTRIC WATER HEATER
Our rudd water heater model #PVP50-1 (50gal) powerglow ignitor will not relight, we have tried to reset, but wil not relight, what do we do now?
The ignitor has gone bad... you will need to find a replacement ignitor and change it..they are not had to change but are very fragile to handle.
That will get you working again...
heatman101
Mar 27, 2010 | Water Heaters
Rheem 71 40d elecrtic water heater not heating
If it is an electric water heater, there is no pilot light. You could have bad elements or bad thermostats. Be careful working on an electric water heater, as most use 208-220 volts!
If it is a gas water heater, it could be a bad thermocouple, ignitor, gas valve.
My advice to you is to call a qualified service company to come repair your water heater.
Jul 09, 2009 | Vanguard International Vanguard BY Rheem...
Bradford White M16u6ss 6 Gallon 120v 1500w Utility Water Heater Logo
167 people viewed this question
Top Bradford White Water Heaters Experts
Gene Haynes
Mack Baxter
David Spradling
David Spradling
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
