Question about Vehicle Parts & Accessories
Small honda engines
Bought new Honda gx630 with no switch box I installed cables and key switch and I have no spark
  • david Jul 29, 2013
    bought new honda gx630 with no switch box installed cables and key switch and i have no spark the hour meter not hooked up
    Top Expert:
  • 50,605 Answers
Check the wiring on the switch as you may have put the start wire on the wrong terminal so that in the run position you have not circuit for the ignition. The switch should be wired in the following way . Off--- first position= ignition ---second position=. ignition and start motor.After the engine starts by releasing the key back to the run position you still have ignition which keeps the motor running
Posted on Aug 02, 2013
1994 honda 4trax no spark
Hi, Jdebord if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Honda TRX 70 No spark fix try this FIRST
5 25 15 1984 Honda TRX200 no spark opened Stator
Honda FOURTRAX TRX300 TRX300FW 4X4 1988 1994 Online Service Manual
http://www.bikebandit.com/oem-parts/1994-honda-fourtrax-300-trx300/o/m151537
http://hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/TRX300-1995.pdf
Dec 01, 2015 | Honda Motorcycles
Honda 20hp wiring diagram
are you trying to install a key switch assembly i can help you just indicate color of wires your dealing with,honda tech 30 years
Aug 25, 2014 | Honda Engine 20hp Horizontal Tapered Shaft...
Spark plugs change
generally the procedure is the following:
- stop the engine
- take off any obstructing panels
- disconnect spark plug cables
- using a spark plug wrench, remove the old plugs
- install the new ones (see your manual for what sort of spark plugs you need)
- reconnect the cables
- start your engine
here's a video example of a 2003 honda shadow spark plug change:
http://www.youtube.com/watch?v=t7b1GropyXE
Jan 24, 2014 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
2004 Honda Ruckus no spark
Hi, Justincollin and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2011 Ruckus with no spark Scooter Doc Forum
Honda Ruckus No spark no electrical anything
https://scootergrisen.dk/scooterhjemmeside/download/honda_zoomer_servicemanual.pdf
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Mar 21, 2013 | 2004 Honda Ruckus Base
1983 Honda GL 1100 Gold Wing no spark
Hi, Anonymous and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
1980 1100 no spark to plugs GL1100 Information Questions goldwingdocs com
GL1100 No Spark HELP
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Gold Wing GL1100 Owner Manual
Aug 12, 2017 | 1983 Honda GL 1100 Gold Wing
2004 Honda XL 650 V Transalp lost both keys
Hi, Larrysaya and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the choke.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Quick disconnect check ball stuck.
14. Compression below 75 PSI.
15. A stuck-bent-burnt valve.
16. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
17. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
18. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
19. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections are loose or connected to the wrong cylinders.
20. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
21. Faulty neutral, clutch, kickstand safety switch.
22. Faulty fuel pump or fuse or relay.
23. Faulty or corroded run/stop switch.
24. Tilt sensor needs a reset.
25. Security system not disarming alarm needs a reset.
26. Check for engine trouble codes.
www TransAlp org
Honda Motorcycles Fault Codes
Honda XL600 650V Transalp XRV750 Africa Twin Service Manual Download... $15
Honda AFRICA TWIN XRV650 Owner Manual
Apr 28, 2011 | 2004 Honda XL 650 V Transalp
1994 HONDA CBX 750 F NO SPARK
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
Vintage and Classic Honda no spark
Troubleshooting No Start Honda Motorcycle
CBX750F 1984 88 HONDA SERVICE REPAIR MANUAL Download Manuals Technical $15
Honda CBX750P Owner Manual
Apr 15, 2011 | 1988 Honda CBX 750 F
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Sep 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
No spark on GV100 honda engine mountfield laser mower have fitted new coil
I assume you replace the coil due to the fact you didn't have any spark. If so, make sure you have the leg gap to flywheel correct. 12 thou should get you spark. However, if still no spark, check out the switch at the lower section of the cable. May only need an adjustment there, as the old cable do stretch with time and the gap is now incorrect. Make sure when you engage the cable that the switch isn't still grounded. Also, check the flywheel key to make sure it's not sheared off. Good luck
Oct 09, 2009 | Garden
Vehicle Parts & Accessories Logo
94 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
