Question about Pool & Spa
VANCS Tsurumi PN Pump 50PN2.4s
My pump makes so much noise that I can hear it 20 feet away. It sounds more like a a swimming pool pump that sits outside the water than a submersible pump. I don't know it that is normal, if it's a bearing can it be replaced or am I better off not messing with it?
  • 77 Answers
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Posted on Apr 28, 2009
  • 59 Answers
SOURCE: Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Posted on May 25, 2009
pippall
  • 1486 Answers
SOURCE: My pump has started making a rumbling noise and is
Bearing worn causing the impeller to shake.When it does this the the impellor is not close to the housing.causing it not to pump very well.Allso the noise you can hear is the impellor rubbing the casting by wobbling when spinning.Hope that was helpfull.Good luck.
Posted on Aug 01, 2009
  • 11 Answers
SOURCE: I lost water pressure in my swimming pool line and
If your pump is blocked in any way (usually a closed valve), then the pump cannot keep water flowing. It could be starved of water if blocked on the suction side, or an air leak. On the return side, it's usually a ``dead head`` pipe, or a closed outlet valve. In either case, the pump can overheat and actually boil the water within it. In that case, the fittings attached to it can deform and cause bigger air leaks, which compounds the problem. If you replace the fittings, reconnect the pipe and remove any blockages, you should be fine.
Posted on Aug 03, 2009
  • 18 Answers
SOURCE: tsurumi submersible vancs series pond pump has
To get a new owner manual send them an email and they will email or send you one,
info@tsurumiamerica.com
Is the pump was working fine for a long time before that happen?
if yes
There is a motor problem,
You can check your pump power cable try to find any damage or hole in it.
If the cable fine
And if the impeller and wheel still turn before triping the breaker It would be a good thing to check the amperage with a special electronic tool to see how much amperage the pump take,
or
if you are good in manipulating tool we can send you the breakdown or i can support you to open it and to check the motor trying to find any burn part in it. That way we will know right away if its worth to fix it.
let me know
Posted on Nov 11, 2009
Which way does the pump suppose to whine?
Thank you for posting your question here on Fixya.com.
A pump can whine for several reasons. Some noise is normal with a pump but when it is very noisy it is indicating a potential problem. If the seal is damaged it may whine and then it usually starts to leak(sometimes a seal leak allows water to get into the bearing at the pump end and reduce its lifespan). If the bearings are damages they will make excessive noise before doing other bad things. These are the most common noises indicating a problem.
If I hear one of these whines I usually make a mental note and let the customer know there is a potential issue. I give them the option of letting it go until it either starts to leak or worse or fixing it right away. Sometimes it operates normally for quite a while while other times it fails very soon. I hope this helps.
If this answer does not resolve your issue, please comment with additional information before rating the answer. Positive feedback is especially appreciated once your problem is solved! Thank you.
Aug 28, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Vancs pump turns off and on.
sounds like something is maybe stuck in the pump causing this problem.
Apr 01, 2010 | Tsurumi Pump s Submersible Trash Pump -...
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Pond pump trips safety switch
Check first if there's continuity between the electrical lines and body of the motor. if there is, then you have a line to ground fault in your motor. If there's none, check the resistance between the phase windings. If you get an infinity value, then the motor windings is shorted. If you get an acceptable resistance value, try to rotate the pump with your hand. If there's a considerable resistance, you might have a defective motor or pump bearings.
Jun 09, 2009 | Plumbing
Tsurumi submersible vancs series pond pump has
if yes
If the cable fine
or
let me know
Jun 09, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Pool pump is making a loud screaming noise. It is pumping ok though.
Sounds like the bearings are worn. If they are you will soon need a new pump.
Jun 08, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
The pump is making a loud noise.
Did you prime the pump? Is it pumping ok, or is it pumping dry? When does it make the noise?.. more info please...
Pump makes loud humming sound, does not pump, eventually overheats and trips breaker. Tsurumi Vancs 50pn2.4s-61
Pull out the oil inspection plug and check oil. It is filled with mineral oil and should appear clear. If milky it would indicate faulty seals. The tsurumis are overheating often in skimmer box applications where the top of the pump is not submersed when the skimmer intake screen gets plugged. Tsurumi no longer accepts pumps for repair at their US facility. If you contact them they may refer you to a recommended rebuilder. It is a shame as we have sold hundreds of these the last 4 years and have suddenly had a rash of this similiar complaint in the last few months with little success in repairing. We have since dropped this line and replaced with Atlantic water Garden Pumps in similiar sizes.
Mar 22, 2009 | Garden
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
