My HP pavilion will turn on but not start up
I got the computer from my uncle an within a week it stopped working. I know pavilions aren't great with airflow so I have the side panel off to help cool it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 35 Answers
Have you tried connecting your PC to another monitor? I'm not seeing the monitor getting any signal. Also, is the computer making any clear internal beeping patterns? Like 2 quick beeps or long beeps etc?
Posted on Jul 30, 2013
  • 8 more comments
  • Nick Buren Jul 30, 2013
    Yes I've tried three different moniters and different cables. Every thing works fine. It was working yester day after I wiped the hard drive and I reinstalled windows and worked great. And there's two small beeps in the begenning but those Are there even when it boots up.
  • CompuPro Service
    CompuPro Service Jul 30, 2013
    If you have a video-card installed on a board with on-board video, meaning you have 2 available spots to plug the monitor into then you might try swapping those
  • CompuPro Service
    Meaning, if your monitor is plugged into the video card rather than on-board video you may be working fine, just not plugged into the default video out. However if you don't have a video card in, or don't have onboard video then it is something else
    It's nothing to do with video im 100% positive of that.
  • CompuPro Service
    CompuPro Service Aug 14, 2014
    Ok, when you say "video", do you mean, you know for a fact the monitor is working and the video output port you are using?
  • CompuPro Service
    The reason I ask is because it's a simple test to verify both. Plug the computer into a monitor that works with another computer. This will verify that it is not the monitor. Then use a different monitor on the "problem pc" and see if you get different results.
  • CompuPro Service
    Just because it was once working doesn't mean it can't suddenly "go out" and quit working. Whether it's monitors or internal pc parts.
  • CompuPro Service
    Cooling should not be an issue at boot, especially if the fans are actually moving. You should be able to start up any pc that is operation will no cooling. Older pcs will eventually burn themselves up, newer ones will just shutdown regardless of what you are doing if they go over temp. But if the pc hasn't been running, it should start up fine with poor ventilation/cooling. On a side note about cooling, "Open Air" cases are terrible for cooling, people like to complain about brand name pcs having air funnels and such attached to the case, but these actually provide highly efficient cooling, they just aren't very up-gradable or changeable, but a mesh style case is about the worst route you can go if you plan to use fans in your case for cooling, watercooling doesn't care about air flow since it only pulls air directly across it's radiator, other than that, no "direction" of flow is needed to maintain temperature.
  • CompuPro Service
    While the service man below is correct about what can cause a blue screen of death or bsod, that is not a blue screen of death, nor should you reach a blue screen of death at initial bootup. The BSOD is windows, and is completely unrelated to bootup. A fault can cause a bsod and bad boot, but a bsod error is not related to anything other than windows as the bsod screen is windows.
  • CompuPro Service
    Testing the RAM/CPU/MB etc is the last route you should go if possible. I would recommend checking whether you cable and monitor are working with another device first or check your computer on another monitor and cable that you know work. IF that is not the problem, then I would recommend, disconnecting all sata/ide cables internally from the MB, depending on your setup it may matter where they plug into, so make a note with a marker or tape on each cable to remind yourself where they go back into. Remove all but one stick of RAM, remove all "addon" cards, such as video cards/network cards etc from any slots on your computer. So at this point, the cpu, fans, power, and one stick of ram should be all that is left in your computer. If you turn it on and get nothing, your board or processor is more than likely shot. USUALLY if it is anything OTHER than the motherboard or processor, you will hear a "beep code" that can be looked up to see what is wrong. When you don't get a beep code, either the MB or CPU is bad OR, your MB doesn't have any self diagnostics, which is rare. You can always look up the MB and see if it has beep codes, if it does, then either the MB or CPU is shot, OR, the computer is actually booting up, you just aren't seeing it, which is why I recommend checking monitor/cables first. If that is the case, then you might just need a cheesy 30 dollar video card to replace the bad port. But this all depends on your setup, and available slots, etc. You didn't provide much detail, the more the better. I hope this helped you or others in need.
akgamit
  • 59 Answers
SOURCE: HP Pavilion a320n PC Desktop - won't turn on
Please visit the link given below and follow the steps to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=364171
Posted on May 29, 2010
  • 1019 Answers
SOURCE: my hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
Posted on Nov 04, 2009
Papa Ray
  • 15 Answers
SOURCE: Battery for your HP Pavilion a375c (DQ109A)?
Please go here: Troubleshooting Power Supply Issues
Posted on Nov 29, 2009
  • 37 Answers
SOURCE: i up graded my hp pavilion 533w power supply to a ...
wrong power supply it sounds like you fried your motherboard
Posted on Jun 01, 2010
  • 10406 Answers
SOURCE: My hp pavilion 513n has completely stopped working! I need help!
Start the computer, and keep pressing F8 until you get a "boot" menu -- white text on a black screen.
Select "safe mode with command-line", and see if Windows will start.
If it does, enter 'CHKDSK C: /F' to get Windows to check the integrity of the file-system.
Then, find a friend with a genuine Microsoft Windows XP CD-ROM. Boot from that disk, and choose "repair", and see if the boot-process can "repair" your installed copy.
Posted on Jun 23, 2010
Laptop turns off when optical drive start to work
i will start with a battery test looks like the motor is drawing too much current for ac support only .
Jul 13, 2013 | Pavilion HP Pavilion DV4-1225dx AC Adapter...
A couple of weeks ago, my HP Pavilion a706n was working completely fine. Soon enough, the first error appeared. I could use it for a good 5-10 minutes and it would shut off by itself. When I attempted to...
If you have cleaned out the dust with compressed air, then I suggest you look at the processor cooling. Is the fan running up to speed? Is the heat sink tightly in place on the processor? Feel the fins of the processor heat sink when you power it up and if they get hot your processor is most likely over heating and shutting down. If all is well at the processor, check the power supply fan to see if it is running and the only other suggestion is to try another power supply. Dust is your worst enemy in a computer.
Aug 14, 2011 | HP Pavilion a706n PC Desktop
Can windows XP be install on HP Pavilion dv7-1132nr with Vista OS
Yes, You can dual boot Windows XP and Vista but you'll be having problem finding drivers if you install Windows XP on this computer since Windows XP supported drivers aren't available on Hp download page. HP has only Windows Vista and Windows 7 drivers for this System.
Hope this helps.
Good Luck.
Thanks for using FixYa.
Jun 13, 2011 | Computers & Internet
Linksys wireless not connected to my mew HP pavioion laptop
Linksys wireless have know to go bad, return and try another one.
Nov 17, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Jul 06, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
MY HP PAvilion F1903 19 " gone black blank
Problem is generally dry solder joints around the inverter transformer on the inverter PCB.
Feb 16, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
390 people viewed this question
David Payne
David Payne
