Question about Singer 4423 Sewing Machine
Brand new Singer 4423 won't go in reverse ?
I just bought this machine brand new. It was just delivered a few days ago. When I sew and press the reverse lever it continues to sew forward. Can't find a solution in the manual. Any advice ?
    Champion:
  • 241 Answers
Your reverse lever may have become disconnected inside the machine. Return it to the dealer if you don't want to fix it yourself.
Posted on Sep 08, 2013
  • 240 Answers
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Posted on Jun 11, 2009
SOURCE: Reverse Lever isn't working...
Most likely the "dogs" inside the lever are broken off. Oil/grease on the metal rod cause chemical attack to the plastic lever and the "dogs" break. Singer should know to degrease this rod before assembly.
Posted on Nov 06, 2009
Zenqi
  • 208 Answers
SOURCE: Antique Singer Sewing Machine AE993349. Looks
You have a model 221 which was made on May 24, 1938 at the Elizabethport factory in Elizabethport, New Jersey. There were 20,000 of those made during that particular run which may have been over a few days.
Its value depends on its overall condition and what someone is willing to pay for it. Sight unseen, I would estimate market value for that machine in good running order at between $250 and $400.
Posted on Feb 21, 2010
SOURCE: My sewing machine is brand new- Singer confidence.
I am having exactly the same problem. I called the Singer helpline and was on hold for 28 minutes before I gave up. I emailed them instead. Did you ever figure out what was going on?
Posted on Aug 19, 2010
  • 539 Answers
SOURCE: Brand new machine. Heavy Duty
Remove plate and place one drop of Zoom Sewing Machine Oil at the bottom left-hand side of race shuttle (you have to remove the plastic section - just unsrcrew with the flat silver thingy in your 4423 accessories. Don't get oil on plastic parts. Remove screws underneath of machine. Tip machine on it's side against a towel. Run machine slowly. Any moving part gets just one drop of oil and gears that look dry get Singer lubricant (Comes in a tube). Make sure you tighten screws, but don't tighten with too much force so you don't "strip" plastic. When sewing heavy fabrics, use Singer Style needles #2032/ 90/14 and 100/16. On TV they demonstrate heavy fabrics and knits with this "heavy duty" machine, I know, but you can bet, you need specific needles for specific jobs no matter if you have a home machine or even a metal industrial. Much success!
Posted on Mar 29, 2012
After less than an hour in all actually sewing on my brand new Singer 4423, it is stuck in reverse. Any suggestions?
Unplug it and read your owner's manual and see what it says to trouble shoot your sewing machine.
Jun 09, 2017 | Singer Sewing Machines
Singer 4423- brand new. Followed youtube tutorial, lowered feed dogs (buttonhole setting) with no problem; now unable to raise them. Followed suggestions to another user with the same problem- no luck
go google and type in --user manual for singer sewing machine model 4423---and download the pdf version
you could always talk to the singer shop for advice or join a sewing club to get expert tips to get the best out of your machine
Mar 22, 2017 | Singer Sewing Machines
Hi ive just retimed my machine but now the bobbin thread isnt been picked up x i have a singer HD 4423 xx
That is generally a timing issue. The needle is arriving at the bobbin at the wrong time to intercept the bobbin thread. Be sure you are using a brand new needle.
Feb 12, 2017 | Singer Sewing Machines
Brand new - never used. The handwheel is really tight and slow
take it to an authorized singer service center and have it adjusted under warranty
Oct 13, 2015 | Singer 4423 Heavy Duty Sewing Machine
Singer 4423 feed dogs won't come back up
The slider on the back of the machine that raises or lowers the dogs is incapable of dislodging the thingamajig when it is gently lodged on the shaft.
Oct 17, 2012 | Singer 4423 Sewing Machine
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Model 4423 singer stuck in reverse
Solution: Turn off machine. Turn stitch dial until you hear click on each stitch shown on dial. Set to straight stitch then and set stitch width to 6. try machine again being careful to put light force on the foot pedal so your not going full throttle. This is how I "de-confused" my Singer Heavy Duty 4423 when it got stuck on reverse. Hope this helps!
Jimmy
Mar 20, 2012 | Singer Sewing Machines
How do i set the timing on my singer 4423 sewing maching?
Copy and paste into your browser, David: http://www.singermachines.com Go down handy free list I found for you to fix timing. Did this help? Jimmy
Feb 17, 2012 | Singer 4423 Sewing Machine
Singer model 9134
i had the same problem
it was stored in a garage (lots of heat) and i had a plastic bobbin
tons of thread on the bobbin side
so i bought new ones (brother brand) same problem
my friend pointed out the brand of bobbin makes a difference
so what the hek a couple more dollors before i toss the machine
and it worked when i bought singer brand bobbins
the heat must have shrank my first ones (like a shrinky dink )
your mileage may very
Dec 29, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 4423 Sewing Machine Logo
97 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
