Question about Dryers
Parts Diagram For Hunter OCL360 disc brake lathe
Need parts list
maklean
  • 1665 Answers
SOURCE: Rowenta DM886
Some parts are here:
http://www.smallappliance.com/product.asp?cur=USD&sid=18995&gid=19001&mid=26&pid=8952&prdCls=P&shopBy=Brand
Posted on Mar 15, 2008
SOURCE: Dorel Model BC-33 Baby Crib need parts list nuts & bolts etc.
I scanned my user guide. Hope it helps.
http://home.comcast.net/~bobwiest/BC-33b.pdf
Bob
Posted on Aug 22, 2009
hondakilla
  • 129 Answers
SOURCE: Hunter The Stonebridge 28870
http://www.hunterfan.com/doc_search_results.aspx?search=2887
Posted on Aug 23, 2009
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
SOURCE: Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Posted on Jun 22, 2010
How to change brake calibers on a drum brakes
Drum brakes don't have calipers - they have wheel cylinders and a backing plate. Do you want to replace it all with original parts, or do you want to convert drum brakes to disk brakes?
A conversion will be very expensive, and might not give you the results you expect. A brake system needs to be thought out carefully to work out all the details before you begin. Like... your proportioning valve will need to be changed, and the master cylinder will probably need to be changed. Then you have to find suitable calipers that can be mounted on your axle.
If you're looking to just replace what's there on a drum brake axle, then... remove the brake shoes exactly as if you were doing an ordinary brake job. The wheel cylinder will be held in place by two bolts from the other side of the backing plate, but you'd better disconnect the brake line FIRST.
If it's very rusty in there, expect a lot of trouble getting things apart. You may end up replacing brake lines, too.
Feb 20, 2013 | Ammco Combination Disc/Drum Brake Lathe
I have an aamco 4000 brake lathe, the disc feed is not working
The cross feed drive shaft is connected to the cross feed spindle via a coupling that resembles a universal joint that is threaded onto the end of the cross feed spindle. Either one of the roll pin holes in the drive shaft coupling has worn and the roll pin fell out or it has broken, or the coupling could have came un-screwed from the cross feed spindle. Remove the 4 bolts that hold the cross feed gearbox on and slowly pull it away from the machine and you should see the coupling I'm describing. My guess is that the roll pin broke or fell out due to wear. You can buy a new drive shaft and coupling or drill and install the next larger roll pin. Either way you should download a parts list for your machine. Just search for it, they can be downloaded free.
Aug 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
I need a abs diagram for a 1996 olds ceria
Autozone's web site has some diagnostic steps you can read through and maybe get an idea of what is wrong. But the first thing you will need is a manual that has the diagrams and parts locations in it. If you are lucky you will find them online but best bet is to spend the $20 or so bucks and buy one so you will have it handy for other needs as well. Another place to look for broken items is the sensors on each wheel. They "read" that toothed ring that rotates with the wheels.
Aug 15, 2012 | Ammco Combination Disc/Drum Brake Lathe
Ammco
Most likely you have a stripped out "disc feed screw."
This is a common problem I see several times a month in the field.
The stripped out portion of the screw is near the end of the feed range obviously.
If you need parts or more questions answered....
Buy Sell Used Brake Lathes Brake Lathe Parts
Jan 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Can i change the discs and pads on a 2003 jag s type 4.2 myself. I have been informed that only jag can do it because the pistons need resetting in the calipers, coz its an electronic brake system?? Is...
it's nearly identical to the lincoln LS, same platform
SECTION 206-00: Brake System 2003 Lincoln LS Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/17/2004
Front Disc Brake adobe.gif Printable View (243 KB)
Material Item Specification High Temperature Nickel Anti-Seize Lubricant
F6AZ-9L494-AA ESE-M12A4-A Brake Parts Cleaner
F6AZ-2C410-AB -
  1. Remove the parts in the order indicated in the following illustration and table.
    Item Part Number Description 1 - Bolts (Part of 2N386) 2 2N386 Guide pin/boot 3 2B120 Brake caliper assembly
    Removal Note
    Installation Note 4 2001 Brake pads
    Removal Note 5 2L200 Slippers 6 N808237-S101 Bolts 7 2B292 Brake caliper support bracket 8 1125 Brake disc
    Removal Note
    Installation Note 9 W701950-S100 Rivets 10 2C208 Brake disc shield
    Removal Note
  1. To install, reverse the removal procedure.
Item 3: Brake Caliper Assembly Removal Note
  1. Remove the caliper flow bolt and the 2 copper washers. Discard the copper washers.
Item 4: Brake Pads Removal Note
  1. Compress the disc brake pistons.
    • Use a wood block or used brake pad to protect pistons and boots.
Item 8: Brake Disc Removal Note
  1. If the brake disc will be reused, match-mark the hub and brake disc.
  1. ani_caut.gif CAUTION: If it is necessary to machine the brake disc, only use a hub-mount brake lathe.
    Measure the brake disc and resurface as necessary. Install a new brake disc if beyond specification.
Item 10: Brake Disc Shield Removal Note
  1. ani_caut.gif CAUTION: Use a 5.5 mm (0.22 in) drill. Do not exceed past a 6.0 mm (0.24 in) drill.
    Drill out the rivets.
Item 8: Brake Disc Installation Note
  1. Clean any rust or foreign material from the brake disc and wheel hub.
    • Use a suitable brake parts cleaner to clean the brake disc and hub surfaces.
    • Apply a suitable anti-seize lubricant to the hub flange.
Item 3: Brake Caliper Installation Note
  1. Install new copper washers.
Aug 04, 2011 | 2003 Jaguar S-Type
Instructions for changing an ammco 3000 brake lathe to a 4000. Parts needed?
Yes, an Ammco 3000 brake lathe can be converted over to a 4000 model--most any year 3000.... preferably the later years after 1970.
The problem with some of the early 60's models is that the cross-feed bore is not perfectly perpendicular to the spindle.
If you convert one of these models, you will cut the rotor at an angle and then jam the machine.
Later models can easily be converted.
You will need...
1) A complete disc feed gearbox.
2) A driven pulley (the big one) set-up for a with a pin drive.
3) A complete spindle lock assembly for the Infimatic gearbox.
4) Possibly need a longer guide bar for the cross-freed. If you have a round guide bar, this is possibly long enough. If you have a "Double-D" guide bar (flat on each side), you most likely will need a longer bar.
5) A complete twin-cutter, with tool guides, tool holders, knobs, etc.
We have all the parts you need for a conversion--or we can convert it expertly for you...
Aug 03, 2011 | Ammco Combination Disc/Drum Brake Lathe
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
Dec 16, 2010 | Ammco Combination Disc/Drum Brake Lathe
Screeching in right rear wheel ,sound stops when breaks applied
its the brake pad wear indicator telling you your pads are in need of replacing
Sep 09, 2009 | 2006 Kia Sedona
I got an ammco 3000 i just have 1 bit on it and i dont have any item number on boring bar,bit holder i just have the bit size that is a little bit small than 7/16 that is 55/128 from base(bottom)to the...
If you live near a machine shop any lathe operator can steer you in the right direction, or you could call them. I'm not certain if Ammco is still in business. I had the same machine in my shop in 1976, not the same model # of course, but a model with the stand.
Aug 22, 2009 | Ammco Combination Disc/Drum Brake Lathe
Dryers Logo
94 people viewed this question
Top Dryers Experts
