Cukoo Clock I have a cukoo clock with a face that says Strong Idea made by Zhong Yang item #JA-2000 the hands are gone and would like another clock insert. If you have one could you please let me know or maybe know where one can be purchased? Thanks, Barry AT: willsoccer@roadrunner.com Thanks again
Noggin
  • 944 Answers
SOURCE: Can't set clock. Can't find Manual
Here is the link to the manual; http://esupport.sony.com/perl/model-documents.pl?mdl=ICFCD553RM Hope this helps, please ask again if you still have trouble :)
Posted on Mar 27, 2007
SOURCE: Projection clock no longer working
just solved my problem that was like yours. turn the clock off at the power for ten minutes and when you turn it back on it should work. mine did!
Posted on Nov 07, 2007
  • 155 Answers
SOURCE: Clock lost 2 hours...
It is probably picking up the wrong signal or your time zone is set wrong. Take out all of the batteries/ power connection etc. then leave it for a few minutes. Then put everything back in and see what it does. It should automatically reset to the right time. If not then try setting manually.
Posted on Nov 20, 2007
  • 281 Answers
SOURCE: Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Posted on Mar 03, 2008
SOURCE: RCA RP5435B SN.1A006J255A0594-Clock running slow
Most of the Radio clocks by RCA are meant to be used with 60Hz AC line. This problem will not go away unles you can get a custom built 60 Hz AC power supply, may prove to be too expensive for the clock.
Posted on Sep 30, 2008
I replaced the battery in my clock the hands go to 12 then stop there. How do I fix?
check to see that the paper of the clock face has not warped to the point whereas it stops the hands if face of the paper withe the numbers on it is not the problem the you can buy new clock motors at micheals craft store for around 7-8 dollars
Sep 29, 2017 | The Computers & Internet
I need to remove the back of my wall clock to tighten the hands, someone glued the face on
no chance to remove the box
it is held in place by a nut on the spindle shaft from the face of the clock under the hands
Jun 20, 2017 | Kenneth Cole 1213 Wrist Watch
La crosse atomic model wt 8005 clock instructions
The WWV broadcast is not really strong in some locations, so if things have changed in your area, like the location the clock is in or addition of items that produce interference like flourescent lights, change them back to the way they were. If that does not work try setting the clock near a window for several days and see. If you dont get synchronized time then the receiver in the unit may have gone out.
Jan 27, 2014 | Home
Minute hand on Braun AB1A has curved up stopping second hand
The whole front square face of the clock has 4 little nails which are located in the middle of each side (inside and next to the edge of the joint), so you have to carefully insert a screwdriver and lever the front out. After this you have to remove the hands (remember to set the clock and alarm hand to 12:00 before taking those away). The face will be loose, and you'll have access to the mechanism. Clean the alarm contact (look for a double silver metal arm that touches an small bronze stick. Alarm button can be release by gently lever the little nail that shows in the center when button is up at clock's backside.
Cheers from Argentina
Jul 04, 2012 | Braun Ab1a Alarm Clock - Black By Rams &...
Ca i put new clockworks in an old clock face - i have a vintage coffee pot clock with a light up perculator that i love- the clock no longer works-the light does- can i just buy a clock mechanism from a...
mcdevito75 here, If the old clock works are Quartz, you may not be able to get a new Quartz movement as it may not be made anymore, BEST BET, look for a small watch repair shop in your area, I'm sure they can do something.
Jul 11, 2010 | Watches
I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
Sounds like it is just worn out.
Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
Here's a link to a site that sells the clock movements... http://www.clockworks.com/
Jun 09, 2010 | Watches
I'm looking for the indash clock wire connection for my 2000 Toyota 4Runner. I would prefer a photo. I was working on my aftermarket radio CD player and reinstalled it. The clock was working before that.
There is 1 fuse for the clock: If your audio system is working then that fuse is OK (instrument panel 18 15 amp fuse). Check it out just to be safe, you never know. If the fuse is OK then the clock itself has gone bad. I've heard of this happening after radio installs, no idea why. Anyway, I have clock removal instructions at www.autoclockrepair.com. I also offer a very affordable repair service with a lifetime guarantee.
Jun 05, 2010 | 2000 Toyota 4Runner
Resetting to daylight savings time.
The clock is searching for a strong enough radio signal from NIST station WWVB. When it can't lock on it, it gives up, moves the dial four hours, and goes to sleep to wait for better reception. Put the clock in a window facing towards Boulder, CO, overnight. (Radio propagation is better after dark.)
Mar 08, 2009 | La Crosse Radio Controlled Atomic Clock
Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
Nov 02, 2008 | Watches
Wall clock not working
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
Feb 22, 2008 | Watches
35 people viewed this question
 Grubhead
Grubhead
