Question about HP Cameras
Digital picture frame says system start won go further
How take picture off add new picture
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
What make and model frame?
Posted on Jul 29, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: Can't download pictures on the digital photo frame
Try another memory card. Or the frame might be bad. I have seen them not work before. If another card works you might just need to reformat the bad card.
Posted on Dec 27, 2008
reitann
  • 214 Answers
SOURCE: Can't view pics on digital frame using new camera
You need to make sure that the pics are on standard jpeg compression, if not try opening file from your pc using mspaint then save file as jpeg
Posted on Jan 08, 2010
tbreeze47
  • 3083 Answers
SOURCE: i have a digital spectrum
You connect it to your computer through the usb port and cord, and drag and drop photos to the frame. Your computer will detect the frame as another hard drive, and you can highlight pictures in the photo album folder, and delete them as well.
Here is the page of your manual that explains it:
http://www.retrevo.com/pdf/23626ag905/11/Connecting+to+the+USB+Ports#q=Digital+Spectrum+MF-1041
Good luck, and hope this helps.
Posted on Dec 26, 2010
How do you load pictures on a pandigital picture
Hello there,
The Pandigital picture frame saves its image files on the memory card. You can put pictures in memory card by inserting it to a memory card reader on the computer and copying pictures to it. Tthe picture frame, then reads the files on the memory card.
Should you need further assistance, please let me know. Thank you for using FixYa.
Aug 07, 2011 | PANDIGITAL (DPF802) Digital Picture Frame
How do you add new photos to the digital picture frame?
Most digital photo frames come with an SD (memory) card that you can plug into a computer and copy the photo's you want from the computer to the memory card. Once done you pop the card back in the frame and your done.
Please be aware that the SD card maybe of limited capacity so you might not be able to get all the photo's you want on it unless you purchase a larger capacity card.
Regards.
May 26, 2010 | Coby DIGITAL FRAME COBY DP102 RTL
Cannot add pictures says it is write-protected to reset norflash
Check that the correct drive letter is selected in the device list at the top right. Try the Norflash Format button in the bottom right corner of the software. If that does not work, your frame is toast.
Jan 17, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Can not add pictures to Kodak
To get a good start, you reformat the frame's internal memory by following the steps below: 1. Click on the "Macintosh HD" icon. 2. Click on "Applications". 3. Click on "Utilities". 4. Click on "Disk Utility". 5. "Kodak" drive should be in the list showing a white drive icon 6. Click that icon and select “Erase”. 7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below. 8. Try to copy the files to the re-formatted internal memory of the frame. 1. Click on the "Macintosh HD" icon. 2. Click on "Applications". 3. Click on "Utilities". 4. Click on "Disk Utility". 5. "Kodak" drive should be in the list showing a white drive icon 6. Click that icon and select “Erase”. 7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below. 8. Try to copy the files to the re-formatted internal memory of the frame. Forget about using any software. Once you connected your frame onto your Macintosh, it will appear as a white drive icon on the desktop. You can copy pictures “drag and drop” from iPhoto to the frame. Just make sure that the pictures you will be copying are in JPEG or EXIF format.
Feb 11, 2009 | Kodak EasyShare SV811 (8858946) Digital...
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Digital frames will not hold more pictures
With a screen resolution of 480 x 234 pixels a collection of 480 x 234 photos would number into the Ka-zillions in number. Since this frame can display jpegs up to 10 Mega-pixels the number would, of course, be reduced significantly.
Nov 29, 2008 | SmartParts INC. digital frame. 7.0 in....
Cameras Logo
19 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
