LG 42PG3000 plasma TV Shutting down Automatically
I have baought a second hand LG 42PG3000 plasma TV it is almost 2 years old TV now when i switch on it shows nothing and the green light turn to RED and shutting down the TV.. then i have given to a shop he told me the Y-SUSTAIN should change... it was little bit expensive so i have ordered new Y-SUSTAIN and changed myself My bad luck... still same problem as i know from google reviews... i am planning to change the power board Will it help me ?? Any new Idea ??
silly girl
  • 513 Answers
SOURCE: TV is dead
Could be many things, possibly a vertical IC failure, or bad soldered joints, or problems with the power supply. Considering your questions, if theres a problem with the tube, you don't want to change it, it won't be worth the expense, and since you're asking, then you probably shouldn't try anything with it. VERY dangerous, more or less like a microwave. TVs store very high voltages even when unplugged. What you could try is to unplug the TV over night, maybe the TV needs a bit of a discharge. also try another power outlet. other then that, you better take it to repair shop. Good luck
Posted on Mar 29, 2006
techman
  • 3130 Answers
SOURCE: How can I remove the little 'green key' in the lower left hand corner of the screen
Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Good Luck
Posted on Jul 27, 2006
jomaru
  • 337 Answers
SOURCE: Power shut off
The set is still sensin a problem thats why it shuts off, in this units the problem is in the vcr section,check the cassette assambly sometimes is jammed and it will not load or one side of the cassette tray is pushed in too far or misaligned.It will continuo to shutdown until the problem is corrected.Be careful when working on it.
Posted on Oct 02, 2006
techman
  • 3130 Answers
SOURCE: rca (tomson)t25062 keeps shutting off
First thing to check would be L401. Its a small coil from the secondary side of the horizontal driver transformer to the Base of the horizontal output transistor. Not a solder problem, You must take it out and scrap off the leads to remove the excess enamel paint the reinsert and resolder. Also check connections on the driver transformer too(horizontal). Next check for bad solder connections on the flyback transformer too. Good Luck PS please dont forget to rate this thread.
Posted on Oct 21, 2006
Danmart
  • 291 Answers
SOURCE: Replace old tv antenna with a new one.
make diagram on paper of the old socket . Carefully unscrewing old socket from wall, DO NOT CUT WIRES, copy color of wires (if any) and where and how meny wires on the paper. EXAMPLE:: you have just pulled old socket away from wall, look and see how meny wires, colors if any, and where they are in contrast to the socket.(left wire=blue, middle wire=black, left=yellow, connector that is up or down=color. MARK these wires on paper, and if possible TAPE a piece of paper with a nember[#] on the wire and place that # on the paper corresponding to the wire in socket wall.
Take the socket to electronics store.NOTE;; IF STORE does not have a exact replacement ask store for SIMULOR replacement.Show the diagram you made to help you buy the right replacement.
Good luck
Posted on May 09, 2008
Can i connect my bose companion 2 speaker to my 42pg3000 plasma tv
yes audio out of your plasma tv use cable bose companion 2 Audio Input Cable with RCA plugs and try
May 20, 2012 | LG 42LG50 42 in. LCD HDTV
Tv wont turn on, geen light flickjers but goes back to red and does ot turn on, i unplugged tv while it was on by accident.
The main board and or power supply is seeing a problem is shutting down the TV.
The cause for your issue could be the power supply, main board, and or the drive board(s) that drive the plasma screen. Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics.
Perhaps the following can help you with a warranty repair.
1. If your TV was purchased from January 1 2008 to today---The TV does have a 1 year warranty on parts/ labor and a 2 year warranty on just the plasma screen.
2. If your TV was purchased before January 1 2008---The TV does have a 2 year warranty on parts/ labor and a 2 year warranty on just the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 60PC1D 60 in. Plasma Television
TV shutting down automatically after a minute
I also have this TV but mine will not power on at all. Did you ever find a solution?
Max.
Jun 25, 2009 | LG MU-60PZ10 60 in. Plasma Television
Power will not stay on
With a problem like this, I would use the warranty for the TV.
It's possible a circuit board failure has occurred and the TV is automatically turning itself off to protect it from further damage. Is normally called " Protection Mode " for most TVs.
Being that it's 2 months old, it should be under warranty regardless. I would recommend contacting the store of where it was purchased and have them help you with the warranty issue.
May 04, 2009 | LG 42PC1DA 42 in. Plasma HDTV
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
