Question about NAD Audio Players & Recorders
Nad 317 protection mode
My nad get's into protection mode and satays there all the time. from i press the on button til i take it off again, I opened it up and checked for anything burned. everything looks intact. i don't know what could do it.
  • henrik monsen Aug 01, 2013
    it does self protect even with no speakers attached. self protects when only the power supply is on
  • NAD Master
  • 5,113 Answers
Assuming the protection circuit is not faulty, I would look to the devices on the heatsink to the cause of the fault.
Posted on Aug 19, 2013
  • 54 Answers
SOURCE: Nad 317 Amplifier No sound
Could be the speaker output relays. GOOD LUCK
BIGRED
Posted on Apr 02, 2008
  • 4234 Answers
SOURCE: Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Posted on Nov 05, 2008
SOURCE: Denon AVC-A1SE in protection mode
After thorough cleaning of the speaker leads, PC Boards etc, I desoldered all the leads of the main two power transistors of the Left channel that had given problem earlier. Switched on the amp and bingo, it did not go in protection mode which confirmed that the two power transitors were the culprit. After checking the voltages and values of some other vital componenets vis-a-vis remaining left channels, it was confirmed that the circuitry was okay. The power transistors were checked again and found to be okay as well. I then took a chance and resoldered not only these two Left channel power trnasitors but also resoldered all the leads of all the other power transistors as well.
The amp was switched on again and this time also it did not go into protection mode. The amp is working fine. Problem could be either dry solder or short of power transistor leads by stray solder waste strand. There was no need to change any part which was great.
Thanks for help anyway.
HJ DALAL
Posted on Nov 30, 2008
petraman7
  • 1175 Answers
SOURCE: NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Posted on Apr 11, 2009
SOURCE: NAD 304 AMP...No Sound at all on both channels, Black marks on inner case.
i need a power amp. brand that has a 4ohms impedance that who will match my 307d2 4 ohms (pioneer) sub woofer that can use inside my house
Posted on Jan 13, 2010
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
Nad C350 2 channel Amp continually in protection mode
That could indeed be the issue, but you must check your speakers, wiring, and also the oupt stages for problems. Maybe the prtection circuits are actually doing their job. lol
Hope that helps...
Geno
Apr 02, 2008 | Audio Players & Recorders
Nad 317
Check for leaky output transistors change emitter resistors
Jul 29, 2013 | NAD Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Protect mode can't use any buttons need the senquence in order to unlock the system
most sharp reset by pressing the power button to enter the power stand-by-mode while pressing down the volume down button ,press the power button un-til ALL CLEAR appears...hope this helps...yammandan
Aug 19, 2010 | Sharp CD-PC3500 CD Shelf System
The print is hardly visible and the ink cartrige is almost full
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Jul 19, 2010 | Dell 922 All-In-One InkJet Printer
I have an av316 NAD, surround sound Amp. Just got back from repair. The wires to the speaker may have been reversed when hooking, the amp went into protection mode, can I fix this problem. It wont come out...
Having the speaker wires hooked up backwords will not cause protect mode. If the wires were crossed (in other words shorted), that would. Disconnect all speaker wires, if the unit is still in protect mode, than the output transistors are probably shorted and the unit will again require service. Upon return from service, I would turn on the unit without speakers to insure that the unit at least works that far. Also, if you have an ohmmeter, measure across the speaker terminals. You should read either 3 or 6 ohms. If you read 0, the problem is a shorted speaker that then shorted the amp.
Keep us posted.
Dan
Jan 20, 2009 | Audio Players & Recorders
Nad C370
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
Ink cartrige wont work
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
511 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
