Question about Plantronics Cs540 Wireless Headset
Plantonics cs540 how can I connect my plantronics cs540 to my rca 25423re1 so I don't have to pick up the handset to use the headset.
  • 5 Answers
SOURCE: Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Posted on Mar 12, 2008
SOURCE: I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Posted on Apr 28, 2009
  • 32 Answers
SOURCE: Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
keekus
  • 83 Answers
SOURCE: plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 20, 2009
I want to buy Plantronics CS-540 online. Recommend a credible website.
Well buying Plantronics CS540 is an excellent choice. You can find various websites online which are offering Plantronics headsets online. I do not know your geographic location but if you are in US then I would suggest that you should check HeadsetZone, Telegiants.com as they usually offer headsets at the most affordable price.
Plantronics CS540
Plantronics CS540
Apr 26, 2017 | Plantronics Radio Communications
I have a plantonics headset that does not pair with my I phone 4s, I have pressed the button on it until the light comes up but no results, I have a plantonics 975
Turn on Bluetooth option within your phone - Consult phone instruction booklet
Put phone into pairing mode - Consult phone instruction booklet
Put the 975 headset into pairing mode - With the 975 headset on, press and hold Call Control Button until the headset begins to flash red and white.
Select "Add new device" on your phone.
Select the Plantronics 975 headset when prompted. Enter "0000" as passcode.
Your 975 headset will now have a continuous white light blinking.
Choose "Yes" if your phones asks if you want to bond to the 975 bluetooth headset.
Your phone is now paired with the Plantronics 975 headset and ready for use.
Dec 22, 2012 | Cell Phones
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
Any tips on the hand set setting for the phone. Everytime I do it, it lasts about a week and then is so loose the arm won't pick up the handset.
It sounds like your HL10 handset lifter is giving you problems. This link has a nice set-up video to help you.
Plantronics HL10 Handset Lifter
Here's a couple of other reminders: Pay close attention to placement of lifter under the handset for proper fit and also how the tape sticks to the phone. Make sure the cord is plugged completely into the base of the wireless headset (needs a good contact). For height adjustment, medium and high work best (the low setting is pretty useless).
Aug 26, 2011 | Plantronics Voyager 500A Deskphone Adapter...
On my new Plantronics S12 Headset System, I hear a dial-tone (through the headset) when I press the headset button, but when I remove the phone and begin dialing nothing happens. I also tried a test call...
Unfortunately, the phone does matter. The S12 is designed to work with office style phones where the handset is just the mouthpiece, all other features located on the base. My suggestion is to get a phone of that style (you can find inexpensive ones at Wally world) and connect the headset following the instructions on this link for the Plantronics S12.
Jun 10, 2011 | Plantronics S12 Headset
Plantronics CS70 is paired with the Yealink EHS36 it will not pick up the line, you can hear nothing but the EHS36 clicking
You are using a Jabra Electronic Hook switch with a Plantronic's headset, they are not meant to go together. Depending on what phone and model you have would depend on the EHS that you would need.
May 05, 2011 | Plantronics CS70 Wireless Headset
I am trying to use a plantronics headset system and cannot get a dial tone. Is this Norstar phone compatible?
You don't say what headset it is, but I will to help you.
If this is a Plantronics corded "H" series headset you will need to use an A10 adapter cord, which plugs into the headset jack on the phone.
If this is what you are using and you don't hear anything then you need to probably need to switch to an M22 amplifier box, which is then plugged into the jack where the telephone handset was plugged in.
If you are using a wireless headset it plugs into the handset jack where the handset cord was plugged into.
Mar 03, 2011 | NorStar M7324 Telephone
I have a plantonics voyager pro. It won't pair with Nokia N86. How could I solve? this problem? Mashary Thank you
There could be interference from other Bluetooth devices on your phone. I would delete or disable them from your phone. You can also try taking the battery out of the phone for about 30 seconds and then try relinking the two. User guide listed below.
Plantronics Voyager Pro User's Guide
Dec 05, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronic 220
HI,
You can get the manual from:
www.plantonics.com
Aug 29, 2008 | Plantronics - Bluetooth Headset Plus Base...
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Cs540 Wireless Headset Logo
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
