Question about Video Game Consoles & Games
Viessmann vitodens 100 boiler makes clicking noise
3 Suggested Answers
SOURCE: I have a vitodens 100-w
Here's the deal: If your Vitodens 100 has outdoor temperature sensing capability, either built in or via external aftermarket control such as Tekmar or other, and the temperature outside is above warm weather shut down (WWSD), then the boiler will not operate for space heating, but will operate to make Domestic Hot Water (DHW) only. Generally speaking WWSD is facoty set at 20*C, since this is normal room temperature so the boiler will not need to operate at temperatures above this number as it is warm enough outdoors to heat the house to comfortable levels.
If your Vitodens 100 does not have outdoor temperature sensing capability then you should check to see if your room thermostats are operational and calling for heat since the boiler is only responding to this on-off control based on room temperature. (turn up your room thermostats)
In both cases you need to make sure that your heating system's distribution pump and zone valves are operating correctly.
In any case you should be calling a heating contractor if you suspect that there is a problem with your boiler and/or heating system.
Good luck.
Posted on Aug 05, 2009
  • 3238 Answers
SOURCE: boiler making clicking noise
contact baxi and ask ther service people there was aproblem with this but i cannot recall it now ,hopethis helps
Posted on Jan 10, 2010
What can I prevent fire
You can prevent fire by many ways.
Do not operate while it has the chance to got fire. IT is the first measure.
Sep 15, 2016 | Viessmann WB1B-26 Vitodens 100-W Gas Fired...
Furnace wont run after running
There are a few posibilities:
1) the oilfilter needs cleaning
2) your pressure reduction bore needs to be changed
3) there is still some air left in the oil-tubes coming from the tank and leads to your burner
The best solution is to call a technician, he'll fix the problem in no time and while he is at it, perhaps he could perform a maintenance
May 29, 2013 | Heating & Cooling
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Boiler making clicking noise
Jan 09, 2010 | Heating & Cooling
Please can someone help me!! We purchased 1 year agao a Viesmann Vitodens 100 Combi Boiler and have had major problems with the flow switch sticking. We have had 3 sub contractors come out and replace...
i am pleased to suggest that you try to following. i would wager that the switch is installed in the horizontal position. try replumbing so that the switch or valve is verticle to the ground. . that way particles will settle down with water flow and not be eating up the gaskets on the valve. in other words flow side to side leaves debris in the valve when it seats. . installed in a vertical position the valve flushes itself as it seats. good luck let me know what happens.
Oct 31, 2008 | Heating & Cooling
How to clean bar 14
Cleaning the calcium carbonate accumulated inside the boiler.Put only 200 ml of water in the water tank then add a 100 grams of citric acid cristals.Do not use coffee holder and open the machine and wait the heater ready lamp .Start the pump .Collect the pumpes acidic water in a cup.When the cup is filled stop the pump and recyle the water collected in the cup to water tank.Ater repeating this recycling 2 -4 times all crystals will be dissolved and the boiler will be filled with this weak acid solution.Wait the machine closed 2 hours.Then put fresh water and run the pump and remove the solution.Now your machine is free of scales inside the boiler. You will notice less noise during boiling of water inside the boiler(not pump noise).After some usage if you notice again that high noise of water boling it is time for another cleaning.
Oct 22, 2008 | DeLonghi BAR 14 Espresso Machine
I have a vitodens 100-w combi boiler and tried to turn the heating on just to give it a working as was advised. However, I have no heat coming to my radiators. The boilers seems to be working as my hot...
Good luck.
Aug 07, 2008 | Heating & Cooling
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
