Question about Garden
Spark plug has no spark
My trimmer was running but poorly and the primer bulb split. I replaced the bulb, fuel lines, filter and spark plug. For a couple of times it would start with the help of carb. cleaner then after that nothing. I found that the spark plug is not getting any spark, what do I do??
  • 1,807 Answers
Check the on/off switch, Check the timing gap between the flywheel and ignition module.
Posted on Jul 29, 2013
  • 2 more comments
  • Bob Murray Jul 30, 2013
    OK I checked the ON-OFF switch and it has continuity, now too small of a gap between the maganet on the flywheel and the module create a problem? I can see marks on the flywheel from where it has hit before, it's not now but you can't get a thick business card between the two. Could that cause the no spark or could it be a bad module. where
  • Plink-plonk
    Plink-plonk Jul 30, 2013
    The ignition module shouldnt touch the flywheel. The magnet in the flywheel passes the module to create the spark, too far away and the spark wont be strong or consistant. The spacing should be a 0.25 feeler guage or the thickness of a standard thin card business card.
    OK the module is closer than it should be, I will adjust it to where it should be. Is there anything else that would keep the module from creating the spark? Is there any way to test the module other than using a spark tester or using the plug to see if there is any spark?
  • Plink-plonk
    You may be able to use an voltmeter to see what the resistance and output is. I dont have the figures for what a functioning one should produce. The gap between the flywheel and ignition module is what gives you the \'advance\'/\'retard\' on the spark.
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 3600 Answers
SOURCE: the primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Posted on Jul 18, 2009
moretons
  • 155 Answers
SOURCE: ryobi trimmer sat for about a year or so, replaced
Hi sounds like the filter mesh inside the carby is blocked and the diaphrams may be hard and not pumping fuel
Posted on Sep 10, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
bbap
  • 71 Answers
SOURCE: my Troy-Bilt trimmer Model TB20CS will not
You have done and are doing exactly what is necessary to solve your problem.
Lastly: remove your carburetor and clean it thoroughly using carburetor cleaner available at most auto parts stores. Replace the diaphragm and metering diaphragm. Diaphragms become stiff with age and with modern fuels and will not pull enough of a fuel-charge into the combustion chamber.
Posted on Sep 27, 2010
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I have a homelite ut20585 string trimmer that i have put a new primer bulb, fuel lines and fuel filter on. i have checked the spark plug and it is good. i cannot get it to fire and run.
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
May 11, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
