Question about Sony NW-A1000 MP3 Player
Sony walkman nv-a1000
Hi, I recently updated my firmware from the sonywebsite to 3.0 for canadian models and now my interface is in chinese (i think). trying to change it to english. If anyone can assist me i would really appreciate it. I already download 2 different firmware and that didnt help.
5 Suggested Answers
SOURCE:
SOURCE: Sony walkman wont work
'try hitting the slide on the side to the top'????
what the heck did that mean???
If you're gonna answer, please people be specific and clear because when we need an answer gobbledegook is annoying!!!
I too had this problem and came here to look for answers, saw that stupid reply and got inspired to solve the problem myself!!!
Hey pal, turn your walkman over (upside down)...see where it says HOLD (its printed into the molding--mine is grey) see the little area directly to the left of the HOLD (note it has three little dots ---there is actually a little arrow pointing to it. Adjust this little area and it should release the hold on the cd. Mine's working again. Hope this helps!
Posted on Nov 05, 2007
SOURCE: NW-A1000 Problem
hgfhfgh
Posted on Sep 07, 2008
  • 82 Answers
SOURCE: Sony SonicStage and NW-A1000
U need to loigin as admin and uninstall and reinstall the softw in a diff location and relocate the database
Posted on Jul 13, 2009
SOURCE: Cant Put Videos in my sony walkman NWZ-E344!!
I don't have a solution either.
Nothing works. :( I tried YouTube free flv convertor on all formats but nuttin.
Posted on Oct 26, 2010
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
After the recent ps3 update, the tv icon is missing from the xmb. I understand it could be a firmware issue but also think it could be linked to the fact that i cannot watch videos on youtube above 240p...
The most recent update to the PS3 firmware changed the TV icon to TV/Video Services. If you are not connected through component cables or HDMI cables, your PS3 will not display anything above 240p. One solution might be to check for updates again, or connect through HDMI.
Aug 23, 2011 | Sony Playstation 3 (PS3) Console
Where can i find firmware updates for LG GSA-4163B dual layer burner - believe it to be A106
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).
The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
Hope this helps you
Aug 21, 2011 | LG (GSA4163B) DVD±RW Dual Layer...
I got the old 407291 software version on my machine and would like to upgrade my firmware, but LG says : Contact your dealer --- Please help
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
hope this helps
Aug 11, 2011 | LG BH08LS20 Blu-ray Burner
Hi i am trying to download songs from my walkman to pc but it says no songs its model sony nw a1000
get a chip that plugs on side of phone and plug chip in computer then a site frost wire download music to chip then you will have music.
Feb 24, 2011 | Sony NW-A1000 MP3 Player
When i wanted to close my mp3, it hangs and the screen shows "power off" and the bass light shines... its been like that for a few hours. tried the reset buttion but no use... HELP :(
1-goto this link http://esupport.sony.com/US/perl/model-home.pl?mdl=NWZB103F&LOC=3
2-you will find a firmware update ubder drivers and download
3-download the firmware and follow the instructions to update the firmware of your mp3 player
4-also read about the "Warning About Counterfeit Memory Stick® Media" because that could also have caused the problem.
Do not forget to rank if i solved your problem
Jan 28, 2011 | Sony Walkman NWZ-B103F MP3 Player
Kicks me of internet after about 10 minutes. Shows connection but will not let me on browser unless I restart
With regards to your concern, I would advice you to perform a firmware update on your router.
Please verify the exact model number of your unit.
The firmware update should be done on the wired machine.
If your using a netgear router. It will perform an automatic update once you log on to the web interface. To log on to the web interface follow the instructions below
1.open internet browser
2. type in the address bar. http://routerlogin.com
3. Enter username as admin and password is password.
4. Once you log on., it will automatically search for available latest firmware. If the automatic update is not turn on. Just click on Firmware upgrade under Maintenance.
CLick on the button search for updated firmware. Once it found the firmware just proceed with the instructions. IF it didnt find any latest firmware. Visit http://netgear.com and select the model number and verision of your router from the drop down list.
Just click support and you will see a download tab which will show you the list of firmwares. Please choose the latest version.
Jul 02, 2010 | NetGear WGR614 Wireless Router
Sony walkman b135 say boot error after that power
Dec 26, 2009 | Sony Walkman NWZ-B135 MP3 Player
China mobile N958 themes download
Hi buddy,
If u want to download a theme for ur china mobile then i dont think there are any themes for china phones. sorry
Jul 26, 2009 | Cell Phones
Chinese language for MINI KA08?
It depends on which version you get - the China market ones generally just have English and Chinese - and the export ones have a number of languages you can choose from, but no Chinese support.
You can reflash one model to the other if you have the correct firmware, but this is more problematic than it seems, since the same phone may have slightly different hardware in it depending on when it was made, and it's not obvious from the outside.
Jun 30, 2009 | Cell Phones
Sony NW-A1000 MP3 Player Logo
193 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
