Question about Home
Sanicompact We have to press the button many times before the motor or pan starts to fill with water can you advise thankso
    Master:
  • 966 Answers
Take off lid and check flushing mechanism if all engaging timely. Adjust if necessary. Good luck. BTW when pressing the button make sure you do it with a bit of pressure.
Posted on Jul 30, 2013
Sanicompact push button is stuck
check flushing mechanism for build ups or rust. clean and try again.
Jul 04, 2013 | Home
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Bread machine arm will not turn except manually
There is a sealed bearing in the base of the bread pan. The paddle rotates on the sealed bearing shaft. The bearing is filled with a lubricant that is sealed inside the bearing. Over time this lubricant may have gotten hard, or the rubber in the bearing got a little brittle. If this bearing sticks the paddle will not spin. The hot water may have loosened everything up. Your friend that told you to use hot water in the pan probably saved you the expense of a new pan. Hank
Jun 20, 2010 | Breadman TR442 Bread Maker
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
Error F06 is Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
Refilling system
Run a clean cycle, might sort it out,
Sounds like it is scaled
Dec 14, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Home Logo
77 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
