Question about Garden
No fire plugs - Garden
  • 1,807 Answers
Please give as much detail as you can. Specific make and model of the equipment, exact problem. Thank you
Posted on Jul 29, 2013
Truck is not firing on 3 cylinders yet it runs.. Runs really rough, back fires, under powered.. Plugs are Wet, Firing order is correct. New Spark plug cables. Don't know that is wrong! Please Help
Check for spark at the plug ( may have coil problem).
If spark is good then do a compression check. Pressure shouldn't be less than 75% of known good cylinders.
Apr 17, 2013 | 1995 Dodge Dakota
2001 Nissan Pathfinder won't start, fuel pressure ok, spark plugs not firing
make sure you have fire at the coil if not there will be no fire to the plugs
Feb 08, 2013 | 2001 Nissan Pathfinder
No spark to engine 1991 ford pickup
It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
Click the link below:------
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Replaced sparkplugs and sparkplug wires, now runs rough. I checked connections all tight. check firing orger, looks right. run good till I touched it. Help.
Check the firing order with the firing order diagram that I have uploaded, and if that does not solve the problem then remove the spark plugs and be certain that there is an even spark plug gap between all of the spark plugs, (see the emission label under the hood for the correct spark plug gap) and be certain that there is not any split-fire or multi-fire spark plugs installed in the engine, because those plugs will not work with an OBD-II system, and a random mis-fire is the least that they will cause if installed in an OBD-II controlled vehicle.
Aug 18, 2010 | 2001 Ford Taurus
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
1984 pontiac bonnerville plug firing order photo
I don't know your engine size, but the link below is a picture of the GM small block firing order with distributor.
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
http://www.classiccarauto.com/impala/how_to/images/distributor.png
Hope this helps...
Aug 27, 2009 | 1984 Pontiac Bonneville
NOT GETTING FIRE TO THE SPARK PLUGS
Hello Momtexas1:
>>Remove the Spark Plugs and Wrap the Threaded Section of the Plug with Wire, then Attach the Other End of the Wire to the Engine Block.
>>**First Make Sure the Plastic End that Snaps to the Plug is Allowing Current to the Plug. Use a Test Light or Multimeter and Check for Fire Behind this Connector (through the Large Rubber like Coil Lead to Plug) for Fire to the Plug whenever there is No Fire to the Plug.**
>>Once you are Sure the Coil Lead and Ends to the Plug are Not the Reason for No Fire to the Plug, then with the Plug Still Wired to the Engine and the Coil Lead Attached to the Plug; Remove the Coil Shut Off Wire at the Shut Off Switch.
>>Check for Fire. If No Fire, then Remove the Cut Off Wire from the Coil (removal of the blower housing required) and Check for Fire.
>>If the Spark Plugs are Firing with the Plugs Out and Properly Grounded to the Engine, then Replace the Plugs and Start the Engine.
>>Using an Insulated Plug Wire Puller, Pull the Plug Wire from 1 Cylinder. If the Engine Continuse to Run, then Replace the Plug Wire and Disconnect the Other Plug Wire. If the Engine Quits, then Replace the Other Cylinders Coil.
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>Thanks.
Respectfully
John
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
