Loading paper in casio hr-150tm
Need to put new roll of tape into adding machine. Can't seem to get it right.
  • 3 Answers
SOURCE: reloading tape roll on a Casio DR-T120
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Posted on Dec 29, 2008
SOURCE: can not load paper
Solved by itense perseverance!
Posted on Feb 13, 2009
SOURCE: loading paper tape
when you first get the calculator there is a black piece of plastic in the very back of the calculator printer with a sliver piece of metal under neath it. push the paper in between the black piece of plastic and the piece of metal and keep pushing feed. at first when i tried this it wouldn't work, but you have to push the paper hard without ruining the piece of paper
hopefully you understand this
and if you have any more questions just please ask
Posted on Jun 08, 2009
SharpCSR
  • 11 Answers
SOURCE: how do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
Posted on Jun 30, 2009
jackcity
  • 33 Answers
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Posted on Sep 13, 2009
Loading paper tape
open the calculator, put the paper in, then put the end of the paper into the slot, close it and that should be it..
Apr 10, 2008 | Casio HR-8TMPlus Calculator
Is there a users manual?
casio, apparently, don't provide a user manual for this model ?
I found a few dubious links (some were dubious in content [they more like a casio mini-catalogue, I didn't investigate], and some looked like spam [they seemed to want to install an installer progam - I didn't investigate these further either.)
I found this which I didn't download or try in any way
CASIO HR 150TM Manuals
be careful with downloads, after you download them before opening do a virus scan, and be on the look out for default liading of unwanted software.
15.January.2016
Jan 15, 2016 | Casio HR-150TM Printing Calculator
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
How do I change the paper tape roll on casio HR-100TM?
Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
Mar 02, 2011 | Casio HR-100TMPlus Calculator
Brand new Casio HR-150TM pringting calculator will not print. It goes thru the motions, but acts as if there is no ink. I can touch the printing wheel and will have ink on my finger, but nothing on the...
There is a plastic protective strip on the printing area. You have to take the ink pad off to remove the strip. Then evry carefully put the ink pad back on. You may need to wiggle the ink pad back on to make sure the black AND red ink is fully engaged. Now if I could just find a manual telling me what the rest of the buttons are for. This user manual is terrible!
Aug 10, 2010 | Office Equipment & Supplies
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
Reloading tape roll on a Casio DR-T120
place the paper sticking out of the top, then close the cover. it will start working; good luck
Jun 02, 2009 | Casio DR-T120 Calculator
How do you replace the paper tape in a Casio HR-8TE calculator?
it should be retively simple, first remove the cover for the printer, then cut the new roll to make a "v" shape at the begining, then slide the paper into the slot and press the feed key until it feeds out. replace the cover and your done.
Thank You,
mikey
Apr 04, 2008 | Office Equipment & Supplies
289 people viewed this question
jasbo
jasbo
