Question about Panasonic SC-HC55 Micro system with iPhone / iPod cradle, Stereo Sound Output Mode, CD, USB-host Media Content Source, CD-RW, CD-R Media Type, MP3 Supported Digital Audio Standards, Radio tuner - AM/FM - digital Type, 45 preset stations Preset Station Qty, 15
Iphone Pairing I cannot get my Iphone and my Panasonic SC-HC55 to pair successfully. My phone discovers it through bluetooth, but it will not pair. I have the radio in "linking" and the phone in discovering, but it always gives me a message that pairing is unsuccessful.
  • 514 Answers
SOURCE: i have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Posted on Feb 22, 2009
SkyGuy08
  • 27 Answers
SOURCE: Pairing Sky+ Remote with Panasonic Viera remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
gopakumarg43
  • 74383 Answers
SOURCE: what code should i use to successfully pair my
Hello
Three digit universal remote codes to check with Panaonic TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit to check with are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Posted on Jul 23, 2011
krishdkiller
  • 384 Answers
SOURCE: how do i fix the pairing of the galaxy s4 bluetooth with panasonic kx-tga651?
delete it from pairing list and pair it again .
Posted on May 25, 2014
Testimonial: "How do I delete it?"
gopakumarg43
  • 74383 Answers
SOURCE: Help I need pairing code for 42 inch Panasonic Viera to YouTube
000281.
Posted on Jul 30, 2015
Lost pairing of iPhone 5 to Panasonic kW tg7841. iPhone will not pair.
I recommend turning the Panasonic back to pairing mode. It probably came with instructions on how to do it.
Jan 28, 2015 | Apple iPhone 5
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
My bluetooth isnt synced to my phone and it isnt. how do i restart the process so that it syncs to my phone??
I have the H715 but my iPhone only showed the H721 instead of the H715. I selected the H721, entered the passcode and connected. Called my home phone with the earpiece in and it works.
From user guide and other user comments...
Make sure the H7xx is fully charged up (not necessary but you'll probably begin to immediately use it and it would be bad to have it discon because the battery is dead). Turn off the H7xx (the ring around the talk button should not be flashing blue every few seconds), push the talk button, thats the oval button on the face of the headset, for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the iPhone.
From the iPhone main menu, select the "Settings" button, then in the Settings menu, select the "General" option.
Touch the "Bluetooth" menu item on the General menu. when the next screen appears, if your Bluetooth is already turned on it will start looking for (discovering) your H7xx. If Bluetooth is not turned on, slide the gray button so it displays "on" instead of "off". Your iPhone should now start discovering your H7xx. It should automatically find your H7xx, then display another screen that prompts you for a code. According to the manufacturer's guidelines, the H7xx requires you put in "0000" that is 4 (four) Zeros as the code.
If everything went well, the "Bluetooth" screen should be displayed again and the Motorola H7xx should show up under the word "Devices" showing that it is Paired.
Your H7xx should now also blink Blue around the talk button.
If things didn't go well. I suggest navigating back to the bluetooth menu. Turning bluetooth off on the iPhone. Flipping closed the microphone boom on the H7xx and starting over again. I had to do it twice because I fumble fingered the 4 zeros.
NOTE: it is not necessary to have the H7xx right on top of the iPhone, but I'd have it within an arms reach, just to be sure you get a good signal and you actually pair to your Bluetooth headset.
Once the iPhone has discovered the H7xx if it continues to state "Not Paired" simply tap the Motorola H7xx box and it will take you to the next screen. Enter "0000" as the security code. The iPhone should now successfully pair with the H7xx.
Apr 01, 2011 | Motorola Mobility H700 Wireless Headset
Iphone 3GS not pairing to plantronics voyager 520
Without turning the headset on, turn the bluetooth on for the phone. Select the headset that is paired, and select Unpair. Then turn bluetooth off. Put the headset into the "discover" mode, by holding down the power button until the light flashes red and blue. Then turn the bluetooth on for the phone, and it should "discover" it. It should ask for the passcode, normally 0000. Once you enter that, it should pair. After that, you should be alright. You can turn the headset off and back on again and it should connect right away.
Hope this helps.
otherwise try this : http://www.plantronics.com/media/media_resources/easytopair/
Jan 12, 2011 | Apple iPhone 3GS Black (16 GB)
My new iphone 4 doesnt discover any bluetooth devices includingother iphones. I cant find any settings to change apart from "bluetooth on/off". My sons HTC will discover th eiphone but wont pair with it....
According to the technicians of Apple, Bluetooth in iPhone does NOT recognize other iPhones/iPods/other brands of phones, because this facility in iPhone is not meant for transfer of data from one phone to the other. It is only for call-hearing and music-listening without keeping the phone attached to the ear.
Oct 14, 2010 | Apple iPhone Smartphone
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
mode immediately.
blinking.
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
pairing.
Thank You
Aug 14, 2010 | Samsung Cell Phones
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do I put it in discover mode?
How to Pair Cardo S-800
1.Turn on your phone and turn ON its Bluetooth function.
2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Feb 07, 2010 | Cardo S-800 Bluetooth Headset Wireless...
I am tryingto pair my iphone with thebluetooth in
The phone needs to discover the car, not the other way 'round.
Make the car BT system discoverable, then on the iPhone go to Settings->General->Bluetooth.
Turn bluetooth on and it will search for devices. It should then find your car, and you can proceed with pairing.
Jan 12, 2010 | Apple iPhone Smartphone
Panasonic SC-HC55 Micro system with iPhone / iPod cradle, Stereo Sound Output Mode, CD, USB-host Media Content Source, CD-RW, CD-R Media Type, MP3 Supported Digital Audio Standards, Radio tuner - AM/FM - digital Type, 45 preset stations Preset Station Qty, 15  Logo
54 people viewed this question
Top Panasonic Radio Communications Experts
Jason
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
