Question about Vehicle Parts & Accessories
Replacing windshield washer pump - Vehicle Parts & Accessories
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
Go to www.automecanico.com and translate this web with your broswer and fix it.
God bless you
Posted on Jul 29, 2013
How hard is it to re place the windshield washer tank on a 99 Olds mobile silouhett
Oldsmobile Silhouette Windshield Washer Reservoir ' Used ...
www.partshotlines.com > All Makes > Oldsmobile > Silhouette
Find a quality Oldsmobile Silhouette Windshield Washer Reservoir and other used Mini Van parts ... For example: If you're looking for a Hood Latch, ... This part is also known as Oldsmobile Silhouette Wdsh Washer Reserv; ... 1999 MONTANA
How To Install Replace Windshield Washer Pump Many GM ...
? 2:34
https://www.youtube.com/watch?v=jCqbhK_-hjY
Jun 7, 2010 - Uploaded by 1A Auto Parts
How To Install Replace Windshield Washer Pump Many GM Vehicles ... can u tell Me were the Fuse located ...
Oct 29, 2015 | Cars & Trucks
Where is the windshield wiper pump located on dodge caravan 2005
The washer pump is located in the bottom of the washer fluid tank
May 24, 2015 | 2005 Dodge Caravan
Where is the fuse for the water pump for the window washer
A washer pump in a car's windshield wiping system moves washer fluid from a reservoir through hoses. The motorized pump pressurizes the fluid to allow it to be squirted from the hoses through nozzles onto the front and/or rear windshield of a car. The washer fluid helps windshield wipers get rid of rain, dirt, or other objects that can interfere with a driver's visibility. If your washer fluid is not being sent out when activated, the solution could simply be filling the washer system's reservoir with more fluid or cleaning the nozzles and hoses. In more severe cases, the washer pump may need to be replaced. Here are steps to troubleshoot a windshield-washer pump.
Try this link in case you are stuck:
How to Troubleshoot Windshield Washer Pump
Here is another YT video for a similar purpose:
Windshield Washer Pump and System Diagnosis
Apr 13, 2015 | 2001 Ford Explorer Sport Trac
How do you replace the windshield washer pump on 2008 ford focus, wipers work but no spray comes out
The hose could be clogged ! Do you know where you add the washer fluid ? Somewhere on the bottom of that plastic bottle is the washer pump .
Removal and Installation
> WARNING: Windshield washer solution contains methanol, which is poisonous. Observe all cautions and warnings indicated on label of washer solution container. Failure to follow these instructions may result in personal injury.
> CAUTION: When replacing the windshield washer pump be careful not to damage the rubber grommet.
> CAUTION: Do not operate the windshield washer pump before filling the reservoir. Failure to do so could result in premature pump failure.
  1. NOTE: When installing the reservoir, the filler neck must be lubricated using a water-based lubricant.
    Remove the bolt and the windshield washer reservoir filler neck.
  1. Remove the RH fender splash shield. For additional information, refer to Section 501-02 .
  1. Remove the foam filler and remove the retainer.
  1. Remove the 2 screws and the accessory drive splash shield.
    • To install, tighten to 5 Nm (44 lb-in).
  1. Remove the nut, 2 bolts and position the A/C accumulator aside.
    • To install, tighten to 9 Nm (80 lb-in).
  1. Unclip the A/C lines from the inner fender well.
  1. Drill out the rivet and remove the bracket.
  1. Remove the 2 bolts, slide the windshield washer reservoir assembly forward to release it, and position the washer reservoir aside.
    • Install the upper bolt followed by the lower bolt, and tighten to 5 Nm (44 lb-in).
  1. Disconnect the windshield washer tube assembly from the pump and release the windshield washer tube assembly from the washer reservoir.
  1. Disconnect the electrical connector from the windshield washer pump.
  1. Release the wiring harness from the reservoir, and remove the washer reservoir.
  1. To install, reverse the removal procedure.
Apr 07, 2015 | Ford Cars & Trucks
How do I change the windshield washer pump on 2002 kia optima
Windshield washer pumps are attached to the windshield washer fluid container. Remove that container and look for the washer pump. That is the only item with two wires connected to it. First remove hose connected to the washer pump and turn the washer switch on. IF water flows from the washer, your water lines are clogged, if no water flows, your washer pump maybe dead or there is no power going to the washer pump.
Try testing IF current is passing/present at the two wires by connecting as continuity tester or simply a small lamp. Switch the washer on and see if the bulb gets lit, if it does, there is power and your problem is the washer pump itself. Replace the pump.
Oct 04, 2014 | 2002 Kia Optima
How to replace the windshield washer pump
pump is in washer resevoir. disconnect electrical plug and hoses then pull pump out.
May 10, 2010 | 1999 Chevrolet Lumina
Windshield washer not working
If you hear the pump running when you try to use the washer pull off the lines on the pump and make sure they're clear. If the lines are clear you need to replace the nozzles. If you don't hear the pump running at all, replace your windshield washer pump.
Dec 30, 2009 | 2001 Mitsubishi Montero
Mercury villager 1994 washer pump not working
the pump motor likely is bad. get a used washer fluid reservoir at a pick n pull yourself or at car-part.com. page with * is lowest cost.
Pump and Reservoir, Windshield Washer Removal
  1. Disconnect the battery ground cable (14301).
  2. Raise and support the vehicle.
  3. Remove the RH wheel (1007).
  4. Remove the RH front fender splash shield (16103). Refer to Section 01-02 for the removal procedure.
  5. Remove the windshield washer reservoir top bolt.
  6. Disconnect the windshield washer reservoir fluid level sensor electrical connector.
  7. Disconnect the rear window washer pump electrical connector from the rear window washer pump.
  8. Disconnect the windshield washer pump electrical connector from the windshield washer pump (17664).
  9. Place a suitable drain pan under the windshield washer reservoir (17618) and drain the washer fluid.
  10. NOTE: The rear window washer hose end is color-coded, matching the connector on the rear window washer pump. Match the colors to ensure proper installation.
    Disconnect the washer hoses from the windshield washer pump and the rear window washer pump on the windshield washer reservoir.
  11. Loosen the two windshield washer reservoir side bolts.
  12. Remove the windshield washer reservoir by sliding it out of the side slots.
  13. Remove the windshield washer pump.
    Installation
To install, reverse the removal procedure. Tighten the lug nuts (1012) to 98-118 Nm (72-87 lb-ft).
Sep 09, 2009 | 1994 Mercury Villager
Windshield washer pump quit working. wipers work ok thou. I can't find an exact replacement.
you can buy a in line pump most anywhere and it just goes in the washer fluid line and the wires from your old pump will need the ends changed to make it work.they come with good instruction.
Aug 29, 2009 | 2002 Hyundai Accent
Washer doesn't work and I can't hear the pupmp motor working.
The windshield washer pump is part of the windshield wash reservior.
There is an electrical connector located on the bottom of the reservior.
That is the pump .
If the pump is not in the reservior. I would just trace the washer fluid lines from the sprayer on the vehicle back to the pump. The lines just might lead back to the reservior for the windshield wash solution. Then you will have confirmed the pump is in the reservior.
You may have to get a new reservior. The pump might not be seperate item, I am not 100% sure on that.
I also would double check the fuses and any relays related to the washer pump.
Finally, I would check the washer switch if you replace the pump and still is not working .
Good luck
Mar 31, 2009 | 2002 Chrysler Town & Country
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
