Question about IBM RS/6000 7013 (57FTOJ50) Server
IBM RISC 6000 Error code
The box will not boot and I'm getting a flashing 888-103-409-094. When I boot into maintanence mode I get several FRU numbers to include for the CPU. I'm unable to locate this code on the IBM web site.
Re: IBM RISC 6000 Error code
Hello, the errors is in this table:
Codes (409-*** errors):
409-094 D16 100 CPU fan failed.
409-095 100 Disk fan failed.
409-096 D17 100 MCA fan failed.
409-097 C92 100 Power supply failed.
409-098 152 100 Power supply hot.
409-Axy 152 100 Power supply internal failure.
Posted on Aug 21, 2013
Re: IBM RISC 6000 Error code - IBM RS/6000 7013 (57FTOJ50) Server Computer Servers
Posted on Oct 15, 2007
POWER supply failed or FAN failure 888-103-409-094
Posted on Sep 05, 2007
0 characters
3 Points
I tried installing windows server 2008 on my Ibm x236. after the installation completes when the system reboots I'm getting error msg. file: \windows\system 32\drivers\wdf01000.sys
that is a Western Digital driver file......for your hard drives likely.
If you are using RAID, then make sure that the RAID is the correct one, and if not, then make sure in the BIOS, you have NOT selected a RAID option.
If those do not seem to be at issue, then attempt to boot in Safe Mode with Networking. That error has been known to have other driver(s) unrelated to the WD driver.
Nov 04, 2014 | IBM X236 Server
Mpc 6000 226 code
What code? Code for what?
Apr 10, 2014 | IBM Computer Servers
Restore lenovo 7540 to factory settings
Where is the reset button on lenovo laptop 7540
Apr 14, 2013 | Lenovo 7540 Ibm 4 Core 4.2ghz Power6...
My IBM System x3650 M2 not booting
We will need more information to help you.
Have you hooked it up to a display, to see where it gets hung in the boot process? Does it get past the BIOS screen? Does it make it into the OS? Do you hear any beep codes?
Apr 10, 2013 | IBM System x3650 M2 7947 (79473AU) Server
Activate lenovo 7540 for bluetooth
Activation could be detrimental to your wellbeing if you do not know what you are doing. Lenovo is the only one with the active code to unlock the system.
Feb 06, 2013 | Lenovo 7540 Ibm 4 Core 4.2ghz Power6...
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Dec 15, 2010 | IBM x3400 Server
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
Ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
Jul 07, 2009 | IBM x3400 Server
Ibm x346 single 2.4 intel xean processor
Hold down F & J keys when booting your server.
Feb 20, 2008 | IBM eServer xSeries 346
IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
Sep 21, 2007 | IBM Netfinity 5600 8664 Server
IBM RS/6000 7013 (57FTOJ50) Server Logo
1,380 people viewed this question
Top IBM Computer Servers Experts
Jax Planet
Jax Planet
Are you an IBM Computer Server Expert? Answer questions, earn points and help others
