Question about Citizen Watches
Hyper B T time keeps flashing
Replacement band for hyper slide
Fixya does not sell replacement bands.
Aug 01, 2016 | Watches
Screen is crack
This is a factory job best outcome for price and outcome. Hope this helps gabe
Feb 03, 2014 | Citizen PROMASTER HYPER AQUALAND DIVE...
How to adjust citizen promaste
What do you mean by adjust it. Do you mean to set the time or are you trying to do something else?
Jul 23, 2011 | Citizen PROMASTER HYPER AQUALAND DIVE...
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
How do i change it from 24 hour to regular time?
When you are looking at the watch you have 2 buttons on the left side, top button being A and bottom button being C. ON the right the top button in B and the bottom one is D. If you press and hold the A button in time keeping mode the numbers will start to flash. While things are flashing, hit the D button and it should switch between 24 and 12 hour times, then hit A again to escape the time setting mode
Aug 17, 2010 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
My watch is solar powered and keeps flashing low....
Is your watch covered for most of the time that it is being worn?( by sleeves perhaps?).
There must be a lower limit of exposure time required to keep the battery charged (so that it can run overnight), perhaps this requirement is not being met.
Feb 10, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do you set the watch for est...
In the time keeping mode hold down the bottom button until a letter starts to flash in the square. Once it's flashing press and release the top button as many times as needed until you get an "E" in the square. Once it has an "E" in the square press the bottom button a total of 10 times to exit the setting mode.
If you need the manual here is a link:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
Mar 17, 2009 | Casio Watches
Watches Logo
44 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
