Question about Holmes Products HASF1516 Stand (Pedestal) Fan
Need new base nut - Holmes Products HASF1516 Stand (Pedestal) Fan
    Top Expert:
  • 12,223 Answers
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
How do I replace a spout O-ring on an American Standard Jasmine Hi-Flow Kitchen Faucet, 3821.831 or .834. I'm trying to get the spout assembly off to get access to replace. Thanks in advance!
The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
Jun 03, 2011 | American Standard Jasmine 3821.831.295...
Replaced our old toilet with this one and now smell coming up from septic will not go away. Did not have this problem before. What can be done to get rid of the smell?
I would suggest that you shut water supply off to your toilet ,disconnect supply line from tank and pull toilet back up. Get a new wax base seal prefreablly a double thick wax type and after cleaning outlet on your toilet reset it on new ring.. Make sure when you tighten retaining nuts that you do so evenly. What I do is carefully center toilet on ring with ring already set in drain flange with bolts in place. Set toilet down on base and push gently from side to side to get bolts thru far enough to get plastic washer and retaing washer and nut on bolts. Carefully tighten bolts going from one side to the other say three turns on each side. Tighten securely,then set on toliet faceing wall and gently rock back and forth,front to back and side to side to help set toilet base in seal. Recheck tightness of nuts and snug up a little if needed. Be careful as the base will break if you overtighten the nuts. Reattach supply ,turn on water and check out. You should be able to get a double thick wax seal at most hardware stores. Good luck. Thanks
Nov 26, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
The antena on my 2005 chev silverado broke off at the base. Is the stud removable or do I have to replace the whole base?
You will have to replace the whole base along with the antena wire that goes into the cab. ON the base you will need to remove the retaining nut. The base will fall into the fender well. You will need to find the antena wire with in the cab, disconnect and reove it with the base. When installing the new antena you will need to put the antena through the fender well and tighten the retaingin nut. Feed the wire back through the are where the old was and reconnect. Good Luck. Please rate.
Mar 08, 2010 | OEM Systems Car Audio & Video
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Tap needs new ''O'' ring on swivelling neck
Usually there is a retaining nut at the base of the spout that unscrews. It looks like apart of the faucet. Once you unscrew the nut, you can pull out the spout exposing two washers that can be replaced. If I had a picture of the faucet, I woul know exactly what to tell you. I'm just using an explanation that are for most faucets. Good luck!
Mar 31, 2009 | Franke Plumbing
Holmes Products HASF1516 Stand (Pedestal) Fan Logo
41 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
