Question about Eureka 2000w 35l Stainless Steel Deep Fat Fryer 2yr Warranty Deep Fryer
Deep fryer bonnet
Pcb 9 color code connection to selector switch
I bought a new thermostat for my for my Depot commercial deep fryer model EFS - 40 at work for 3 days after that I just cut off and won't come back on so what would be the problem
Questions, Troubleshooting Help & Support Page 9 - Fixya
www.fixya.com/troubleshoot/page-9
I bought a new thermostat for my for my Depot commercial deep fryer model EFS -40 at work for 3 days ... SHOWS NO SIGNAL IT WAS WORKING FINE UNTILL I TRYED THE FAV BUTTON ... Once I found a fried ground wire in trunk replaced.
Sep 25, 2015 | Kitchen Appliances - Others
Wire diagram to make sure three wires are connected correctly to the lighted rocker switch
Normally the neutral lead of the lamp is a different color. If you have a ohm meter you can use it to look for a short between two terminals, this is the switch. The lamp is likely a neon lamp that you can not read with a meter, neon must have over 60V to light.
Dec 05, 2014 | Hamilton Beach 35030 Deep Fryer
Reset switch uniworld electric counter top deep fryer
There is no reset switch. If there is a problem, a repair must be made to make the deep fryer work properly again.
May 20, 2014 | Frymaster Dean SR42G Deep Fryer
Pilot lights but will not light burners when range selector dial is turned on
Hi there.
Check and clean the thermopile, it must be free of soot or any form of dirt so that it can properly sense heat from the pilot flame and generate millivolt to open main valve to fire up main burners.
Regards.
Sep 22, 2011 | Pitco Frialator 35CS Deep Fryer
Steaming
Per page 9 of the manual, add water until it reaches the bottom of the basket and do not allow the water to evaporate.
http://www.masterbuilt.com/pdf/manuals/20010406%20&%2020010306%20Digital%20ETFV.pdf
Jan 01, 2009 | Masterbuilt 20010406 Deep Fryer
Adcraft double deep fryer
its safety switch not functioning
Jul 03, 2008 | Adcraft DF-6L/2 Deep Fryer
Deep Fryer doesn't get up to a proper temp.
9 TIMES OUT OF 10 THE TEMPATURE DIAL ON ANY DEEP FAT FRYER IS NOT FULLY ACCURATE TO MAKE SURE YOUR FOOD IS PROPERABLY COOKED YOU WOULD HAVE TO LEAVE IT THAT BIT LONGER
Jan 09, 2008 | Rival CF275 Deep Fryer
Eureka 2000w 35l Stainless Steel Deep Fat Fryer 2yr Warranty Deep Fryer Logo
46 people viewed this question
Top Eureka Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Eureka Kitchen Appliances - Other Expert? Answer questions, earn points and help others
