Question about Refrigerators
Aeg santo n7 18 40 4i
When should fan in freezer compartment run
  • 1462 Answers
SOURCE: I have an electrolux Aeg
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Posted on Oct 08, 2008
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
heatman101
  • 43501 Answers
SOURCE: fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
SOURCE: AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
Posted on Nov 30, 2010
  • 83 Answers
SOURCE: how do i set my
Hi
The santo was originally built with a standard thermostat, this is graduated from 1 to 6 where 1 is the warmest setting and 6 is the coldest, normally you would set this to btween 3 and 4 and adjust it slightly to your favourite.
Regards
Gordon
Posted on Apr 20, 2011
Door for freezer compartment for AEG refrigerator Santo 1450-7TK
Fixya does not sell freezer compartment doors. Check with a local appliance parts supplier.
Nov 07, 2016 | AEG Refrigerators
Aeg freezer getting hot on the sides
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink
May 11, 2012 | AEG Santo 7388 KG Side by Side...
I have a aeg santo 91842 4i, integrated fridge-freezer, just over 2 years old.-i know just out of ganantee!! it keeps leaking water from the bottom, (underneath the freezer compartment),and i just cant...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 07, 2011 | AEG Refrigerators
Aeg santo has stopped working, no power to it
Check the wall outlet for power and your breaker box for a popped breaker. Rate me if I am correct!
Aug 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Fridge freezer not keeping temp
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Mar 16, 2009 | Refrigerators
Santo S 75398 KG3
My freezer is working well, however the top refrigerator has stopped cooling, what should I check begore calling a repair man?
Nov 30, 2007 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
229 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
